I have a Local Web server on my LAN. Its IP is 192.168.110.3. The DNS name is “airavenue.contegris.com”. It’s working fine on LAN.
But I have to access it remotely so I configured Wireguard. It accessible only with IP 192.12.168.110.3 and not accessible with its domain “airavenue.contegris.com”
Thanks.
add name=Bridge_LAN port-cost-mode=short
add name=“Bridge_LAN Central Park” port-cost-mode=short
set [ find default-name=ether1 ] name=ether1_WAN
/interface pppoe-client
add disabled=no interface=ether1_WAN name=PPPoE_user=0XYZZZZZC
/interface eoip
add local-address=xx.xx.xx.xx mac-address=07:72:00:1D:09:39 name=
“EoIP Tunnel_Central Park” remote-address=xx.xx.xx.xx tunnel-id=xxx
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add name=dhcp_pool ranges=192.168.110.100-192.168.110.200
add address-pool=dhcp_pool interface=Bridge_LAN name=dhcp1
/ppp profile
add dns-server=8.8.8.8,1.1.1.1 local-address=192.168.84.1 name=sstp-profile
remote-address=VPN-pool
/routing table
add disabled=no fib name=to_L2TP
add bridge=“Bridge_LAN Central Park” interface=“EoIP Tunnel_Central Park”
internal-path-cost=10 path-cost=10
add bridge=“Bridge_LAN Central Park” interface=ether2 internal-path-cost=10
path-cost=10
add bridge=Bridge_LAN interface=ether3 internal-path-cost=10 path-cost=10
add bridge=Bridge_LAN interface=ether4 internal-path-cost=10 path-cost=10
add bridge=Bridge_LAN interface=ether5 internal-path-cost=10 path-cost=10
set udp-timeout=10s
/interface wireguard peers
add address=192.168.110.1/24 interface=Bridge_LAN network=192.168.110.0
add address=192.168.181.1/24 interface=wireguard1 network=192.168.181.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-server alert
add disabled=no interface=Bridge_LAN valid-server=18:FD:74:B3:A2:50
/ip dhcp-server lease
add address=192.168.110.101 always-broadcast=yes comment=“Windows 10 Laptop”
mac-address=74:70:FD:1D:CE:23
add address=192.168.110.102 always-broadcast=yes comment=“Windows 11 Laptop”
mac-address=74:E5:F9:D1:59:F2
add address=192.168.110.103 always-broadcast=yes mac-address=
00:0C:29:CC:84:1B
add address=192.168.110.0/24 dns-server=192.168.110.1,8.8.8.8,8.8.4.4
gateway=192.168.110.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.110.3 name=airavenue.contegris.com
add action=accept chain=input comment=“Router Access Remotely” dst-port=
4477,4478 protocol=tcp
add action=accept chain=input comment=“Web Allow” dst-port=53 in-interface=
Bridge_LAN protocol=tcp
Bridge_LAN protocol=udp
add action=drop chain=input comment=“Block Attack” dst-port=
25,53,87,512-515,543,544,7547,8080 protocol=tcp
53,80,87,161,162,1900,4520-4524,8080 protocol=udp
add action=add-src-to-address-list address-list=“Port Scanners”
address-list-timeout=none-dynamic chain=input comment=
“Port Scanners to Address List " protocol=tcp psd=21,3s,3,1
“TCP Flag-NMAP FIN Stealth scan” protocol=tcp tcp-flags=
fin,!syn,!rst,!psh,!ack,!urg
“TCP Flag-FIN/SYN scan” protocol=tcp tcp-flags=fin,syn
“TCP Flag-RST/SYN scan” protocol=tcp tcp-flags=syn,rst
“TCP Flag-FIN/PSH/URG scan” protocol=tcp tcp-flags=
fin,psh,urg,!syn,!rst,!ack
“TCP Flag-ALL/ALL scan” protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
“TCP Flag-NMAP NULL scan” protocol=tcp tcp-flags=
!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment=“Dropping Port Scanners”
src-address-list=“Port Scanners”
add action=masquerade chain=srcnat src-address=192.168.110.0/24
add action=masquerade chain=srcnat src-address=192.168.181.0/24
add action=dst-nat chain=dstnat comment=“Windows 10 Laptop” dst-address=
xx.xx.xx.xx dst-port=4480 protocol=tcp to-addresses=192.168.110.103
to-ports=3389
add disabled=no dst-address=0.0.0.0/0 gateway=PPPoE_PTCL routing-table=main
suppress-hw-offload=no
add check-gateway=ping disabled=no distance=1 dst-address=192.168.94.0/24
gateway=192.88.16.2%*F00024 pref-src=”" routing-table=main scope=30
suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=192.168.94.0/24 gateway=
192.88.16.3%*F0002D routing-table=main scope=10 suppress-hw-offload=no
