AS much as it possibly can!
This is not just a router, Its a mikrotik one, they do every thing[*]
Nothing, thats why i want to do it on the mikrotik that i currently have, Yes you can just get apache but then u need a computer and its gona run the whole time. If possible why not just have it on your mikrotik, It makes more sense in regards to reliability, cost and power consumption.
I just thought that if it does it for hotspot it could be done for some thing else. Upload the files to File manager then create a firewaall rule and it should just work…
I don’t think you can serve much more than just static files and it won’t support too many concurrent users, probably RouterOS isn’t optimized to be used in that way. Also, I don’t know if RouterOS license will allow you to do that.
To be honest, i can’t be bothered anymore. Fewi said the same in less words.
Your question is inane.
If you make money from what you do, you should be prepared to put something back into the infrastructure you maintain.
The idea of having a router/webserver/games server/web cache/dns cache/Asterisk server is just plain silly - especially when you buy a very resonable priced router.
What if that router gets busy ? Ditch the web server ? Keep the web server and ditch the Routing ?
The idea of messing about with a router for Months to save maybe 40 euros on, say, a UBNT RouterStation to act as a hardly-used web server is just not worth pursuing - especially whan you are making money from your reasonably priced routers.
