This might help:
I masked WAN ip addresses and sensitive information left behind by /export hide-sensitive file=somefile
Office config:
# jul/30/2022 14:53:59 by RouterOS 6.49.6
# software id = W0PA-KWSM
# model = CRS109-8G-1S-2HnD
# serial number = D54XXXXXXF6A
add arp=proxy-arp name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=ap-bridge \
ssid=NCnet wireless-protocol=802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=aes-256,3des
add enc-algorithm=aes-256 name=profile1
/ip ipsec peer
# This entry is unreachable
add name=peer1 passive=yes profile=profile1
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha512,sha256,sha1 enc-algorithms="ae\
s-256-cbc,aes-256-ctr,aes-256-gcm,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-\
128-ctr,aes-128-gcm" lifetime=0s pfs-group=none
add name=dhcp ranges=10.0.0.2-10.0.0.244
add name=l2tppool1 ranges=10.0.0.245-10.0.0.254
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8 local-address=10.0.0.1 name=\
vpn-prof remote-address=l2tppool1 use-upnp=no
set *FFFFFFFE change-tcp-mss=default dns-server=8.8.8.8 local-address=\
10.0.0.1 remote-address=l2tppool1
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=sfp1
add bridge=bridge1 interface=wlan1
add bridge=bridge1 fast-leave=yes interface=*D
/interface l2tp-server server
set authentication=chap,mschap1,mschap2 default-profile=vpn-prof enabled=yes \
one-session-per-host=yes use-ipsec=yes
add interface=ether1 list=WAN
/interface ovpn-server server
set auth=sha1 certificate=server cipher=aes256 require-client-certificate=yes
/interface sstp-server server
set authentication=mschap2 certificate=SERVER enabled=yes force-aes=yes pfs=\
yes port=4430
add address=10.0.0.1/8 interface=bridge1 network=10.0.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10h10m
/ip dhcp-client
add disabled=no interface=ether1
/ip dhcp-server lease
add address=10.0.0.10 mac-address=FC:A2:12:28:A8:4B server=dhcp1
add address=10.0.0.11 client-id=\
ff:b5:5e:67:ff:0:2:0:0:ab:11:1e:36:a9:55:2a:9f:b4:bc mac-address=\
00:A0:58:59:4F:61 server=dhcp1
add address=10.0.0.0/8 gateway=10.0.0.1 netmask=8
set allow-remote-requests=yes
/ip firewall address-list
add address=43.230.209.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=43.231.131.0/24 comment=AFGHANISTAN list=CountryIPBlocks
add address=197.157.204.0/22 comment=ZIMBABWE list=CountryIPBlocks
add address=197.221.224.0/19 comment=ZIMBABWE list=CountryIPBlocks
add action=accept chain=input dst-port=80,8443 in-interface-list=WAN \
protocol=tcp
established,related,untracked
add action=accept chain=input dst-port=443 in-interface-list=WAN protocol=tcp
invalid
add action=accept chain=input dst-port=8291 in-interface-list=WAN protocol=\
tcp
add action=accept chain=input comment="SSTP server nancy 4430" dst-port=4430 \
add action=accept chain=input dst-port=1701,500,4500 in-interface-list=WAN \
protocol=udp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-esp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes
add action=drop chain=forward disabled=yes in-interface-list=WAN \
src-address-list=CountryIPBlocks
add action=dst-nat chain=dstnat dst-address=2xx.xxx.xxx.xx9 dst-port=443 \
protocol=tcp to-addresses=10.0.0.11 to-ports=443
add action=dst-nat chain=dstnat comment=WEB dst-port=80 in-interface-list=WAN \
protocol=tcp to-addresses=192.168.88.2 to-ports=80
add action=dst-nat chain=dstnat dst-address=2xx.xxx.xxx.xx9 dst-port=8443 \
protocol=tcp to-addresses=10.0.0.11 to-ports=8443
add action=dst-nat chain=dstnat disabled=yes dst-address=2xx.xxx.xxx.xx9 \
dst-port=80 protocol=tcp to-addresses=10.0.0.11 to-ports=80
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
/ppp secret
add local-address=10.0.0.1 name=ncvpn profile=vpn-prof remote-address=\
10.0.0.252 service=l2tp
add name=axtest profile=vpn-prof service=l2tp
add local-address=10.0.0.1 name=nctunelaxo remote-address=10.0.0.2 routes=\
"192.168.88.0/24 10.0.0.2 1" service=sstp
add local-address=10.0.0.1 name=nctunelnancy remote-address=10.0.0.3 routes=\
"192.168.90.0/24 10.0.0.3 1" service=sstp
/system clock
set time-zone-name=America/New_York
/system identity
set name=NCnet
/system ntp client
set enabled=yes primary-ntp=129.6.15.28 secondary-ntp=129.6.15.29
shop router:
# jul/30/2022 15:05:52 by RouterOS 6.49.6
# software id = Q0V4-43P8
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7DXXXXXDCB
add admin-mac=CC:4D:A0:D4:52:54 auto-mac=no comment=defconf name=bridge
add name=bridge-loopback
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=sfp1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
default-forwarding=no disabled=no distance=indoors frequency=auto mode=\
ap-bridge ssid=MikroSSID station-roaming=enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-Ceee disabled=no distance=indoors frequency=auto mode=\
ap-bridge ssid=MikroSSID-5G station-roaming=enabled wireless-protocol=\
802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
mode=dynamic-keys supplicant-identity=MikroTik
/ip ipsec policy group
add name=group.vpn.ike2
/ip ipsec profile
add dh-group=modp2048,modp1536,modp1024 enc-algorithm=aes-256,aes-192,aes-128 \
hash-algorithm=sha256 name=profile.vpn.ike2
/ip ipsec peer
add exchange-mode=ike2 local-address=2xx.xxx.xxx.xx2 name=peer2xx.xxx.xxx.xx2 \
passive=yes profile=profile.vpn.ike2
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1 enc-algorithms="aes-256-cbc,aes-256-ctr\
,aes-256-gcm,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm" \
name=proposal.vpn.ike2 pfs-group=none
/ip kid-control
add name=mam
add name=dhcp ranges=192.168.88.2-192.168.88.254
add name=pool.vpn.ike2 ranges=192.168.90.2-192.168.90.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ip ipsec mode-config
add address-pool=pool.vpn.ike2 address-prefix-length=32 name=\
modeconf.vpn.ike2 split-dns="" split-include=0.0.0.0/0 static-dns=\
192.168.90.1 system-dns=no
/ppp profile
set *FFFFFFFE dns-server=192.168.88.1 local-address=192.168.88.1 \
remote-address=dhcp
/interface sstp-client
add authentication=mschap2 connect-to=216.215.129.149:4430 disabled=no \
http-proxy=0.0.0.0:4430 name=sstp-out1 pfs=yes profile=default-encryption \
user=nctunelaxo
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
/interface bridge settings
set use-ip-firewall=yes
set use-ipsec=yes
set authentication=mschap2 default-profile=default-encryption force-aes=yes \
pfs=yes
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
add address=192.168.90.0/24 interface=bridge-loopback network=192.168.90.0
/ip cloud
set ddns-update-interval=30m
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set servers=192.168.88.1
/ip dns static
add address=192.168.88.1 name=router.lan
add address=192.168.88.10-192.168.88.255 list=client
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" disabled=yes dst-port=1701 \
protocol=udp
add action=accept chain=input comment="allow pptp" disabled=yes dst-port=1723 \
protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=forward comment="LUNA TABLET BLOCK" disabled=yes \
src-mac-address=1C:93:C4:B4:EF:29
invalid
connection-state=invalid
add action=reject chain=forward comment="Client Isolation" disabled=yes \
dst-address-list=client reject-with=icmp-network-unreachable \
src-address-list=client
add action=drop chain=forward comment="Stop internet" disabled=yes hotspot="" \
out-interface=!all-wireless time=\
15h47m-15h48m,sun,mon,tue,wed,thu,fri,sat
add action=dst-nat chain=dstnat dst-address=2xx.xxx.xxx.xx2 dst-port=443 \
protocol=tcp to-addresses=192.168.88.100 to-ports=443
add action=dst-nat chain=dstnat dst-address=2xx.xxx.xxx.xx2 dst-port=80 \
protocol=tcp to-addresses=192.168.88.100 to-ports=80
add action=dst-nat chain=dstnat comment="RDP Externo" dst-address=\
2xx.xxx.xxx.xx2 dst-port=4000 protocol=tcp src-port="" to-addresses=\
192.168.88.100 to-ports=4000
add action=dst-nat chain=dstnat comment="iperf tests" dst-address=\
2xx.xxx.xxx.xx2 dst-port=5201 protocol=tcp to-addresses=192.168.88.100 \
to-ports=5201
add action=dst-nat chain=dstnat comment="SSH Externo" dst-address=\
2xx.xxx.xxx.xx2 dst-port=4022 protocol=tcp to-addresses=192.168.88.100 \
to-ports=22
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.88.0/24
add action=netmap chain=dstnat disabled=yes dst-port=80 in-interface=ether1 \
protocol=tcp to-addresses=192.168.88.89 to-ports=80
add action=dst-nat chain=dstnat comment=HTTP:80 disabled=yes dst-address=\
2xx.xxx.xxx.xx2 dst-port=80 protocol=tcp src-port=80 to-addresses=\
add action=dst-nat chain=dstnat comment=HTTPS:443 disabled=yes dst-address=\
2xx.xxx.xxx.xx2 dst-port=443 protocol=tcp src-port=443 to-addresses=\
/ip ipsec policy
add dst-address=192.168.90.0/24 group=group.vpn.ike2 proposal=\
proposal.vpn.ike2 src-address=0.0.0.0/0 template=yes
add distance=1 dst-address=10.0.0.0/8 gateway=sstp-out1
/ip service
set www disabled=yes
/ip smb
set allow-guests=no domain=casaSSD
/ip smb users
add name=casa read-only=no
/system clock
/tool mac-server
/tool mac-server mac-winbox
