Webbox and 3.28
Just looked through the change log and did not see any fixes related the web interface. Was the “interfaces” cfg page fixed to work? Any of the other enhancements like being able to enable/disable nstreme (checkbox), set port forwarding, enable UPnP, use wireless snooper, etc?
I will take a look, but without the fix to interfaces cfg page, we cannot move up. We are currently stuck at 3.23 until this gets resolved.
Every release I post this same request and several other users chime in with their agreement, but it never gets fixed.
Please…
Webbox is working in 3.28 on x86, exactly as they said earlier =)
I can confirm webbox is working on 3.28 x86.
Thank you Mikrotik for fixing this issue.
and on RB532.
it did work on RBs, doesn’t it?..
Probably :slight_smile:
I just can’t remember on which Router I had the problem on but you’re right, it’s the x86 where the webbox was broken in the later releases.
Sorry to mislead anyone.
Take it as ‘Webbox STILL WORKS on RB532s’ :lol:
