Webbox Basics
Hi. This may seem like a dumb question, but I can’t seem to access Webbox…how do I access Webbox? I have tried surfing to the IP address, then to IP/cfg, but nothing appears. I have port 80 service enabled.
Am I missing something simple? I believe I have all required packages installed.
Also, anyone know about the “API” which was to be included in 3.X for customizing Webbox?
Thanks!!!
Webbox is here:
ip/cfg/login and is available unless blocked by firewall.
API docs for 3beta are here:
http://wiki.mikrotik.com/wiki/API
Mike
it was nothing to do with webbox, api is if you want to build your own winbox or something like that
if, in webbox you set - Protect router, then you wont be able to connect to it through WAN ports - so access has to be local only.
