I have been trying to get the webbox login working, I just can’t figure it out…
I am able to telnet and use winbox from this pc, but I can’t get in with webbox, after clicking login, it just says failed to connect.
Is there any setting, such as ACLs with regards to webbox administration?
I noticed the same when upgraded from 3.23 to 3.24 on three different HW: the interface tab not found.
If I try to goes back webbox request new login.
On two of them (WRAPs) the root page is “quick” and I can surf around except when I select interface tab (page not found, went back on hystory and webbox asks for a new login).
At the the third HW (regular PC desktop machine) the root page is “interface” and no way to uses webbox there. Even copying+pasting another page address => new login = redirect to interface page (not found).
I have the same problem in 3.24. If I login with an incorrect username / pass, I get an error page from the router, but when I enter a correct username / pass I get a failed connection message from the browser itself. No, it’s not the users, it’s the software.
First it was Dude web that quit working (after it was working fine until a specific upgrade version), and now Webbox (which also quit working after a specific upgrade version). Please Mikrotik, I ask of you: PLEASE TEST YOUR SOFTWARE BEFORE RELEASE (supposedly that’s what their beta is for). Please please. We are paying customers.
I’m a happy costumer when stuff works, but I just have a real hard time justifying breaking something that used to work in a previous version, especially when it has worked for many versions before. If it’s a new feature then maybe I can understand a bit more, but come on guys! This has happened too many times for me when using Mikrotik products and doing upgrades (both fresh install to newer version and in-place upgrades), which are supposed to be better, more stable, yada yada.
Like I said before, Mikrotik, if you need people to write and test code, let me know. I really want to believe this is production quality, but i just don’t see that at the moment.
