Webbox UI, Protect LAN option
What does the Protect LAN option does over and above Protect ROUTER ?
f.
you can select it, and then check what rules it added via Telnet. A word of advice, if you use Webbox for configuration, use ONLY webbox, otherwise the configurations could conflict.
