Webfig access via reverse proxy
I’ve set up Adito (SSL-Explorer successor, http://sourceforge.net/apps/trac/openvpn-als/wiki/) to provide me a way to access home resources on the go. I’ve managed to set up RDP, SSH and certain reverse web proxy connections, but I am having trouble with Webfig. Here is some info on the reverse web proxy in Adito: http://sourceforge.net/apps/trac/openvpn-als/wiki/web_forwards
When I set up a Webfig connection using the tunnelled web forward option (using the Java VPN client), it works fine. But when I try to set it up using the reverse proxy, or path based reverse proxy, so that I do not need the client, I get the login page for Webfig but when I login using correct credentials I get the following error in red:
ERROR: Not Found
Any ideas?
