WEBFIG bugs on 5.15
A few days ago I spent some time testing skins on 5.15.
I posted this on the “RouterOS 5.14 Webfig Two Terrible Bugs” but seems that noone looks at that, so I opened this new thread
the good part is that the “design skin” button is gone in the user webfig interface
BUT
given that the user “cicci” is in a group with read,write and web policy linked to the “minimal-wlan” skin, I attach my configuration and my results.
configuration screenshot: on wireless I enabled only “address list” and “registration”
Wireless Tables at admin@201.0.1.130 - Webfig v5.15 on _2012-05-04_10-54-26.png
user screenshot: when the user logs in he sees this, and nothing else to reach the other wireless configurations
Wireless Alignment Settings at cicci@201.0.1.130 - Webf_2012-05-04_10-53-46.png
this is the json file for that skin:
minimal-wlan.json.txt (1.85 KB)
SOMEONE CAN EXPLAIN ME?
  • is it my error?
  • is skin design already broken?
SOMEONE CAN GIVE ME A SUGGESTION?
  • which version I have to downgrade to give my customer a skin just for adding some mac addresses to a wlan interface?
  • should I go through API? I’m not a programmer, someone can hint?
Thanks for ANY suggestion you can give me
dtoffo, thank you very much for the report.
I repeated the same problem on my wireless AP, problem was reported and it will be fixed in the next RouterOS version.
Thanks sergejs
I hope 5.16 will be available soon… my customer is a bit angry
IN 5.16 IT’S THE SAME !!!
… what a shame!
(… to make the rhyme … )
:frowning: :frowning: :frowning:
should I go for API ?
The issue will be fixed at the next RouterOS version 5.17, we are sorry for the inconvenience.
I confirm it is ok in 5.17 :smiley:
