Webfig IPv6
I am working on setting up IPv6 on my CCR1036 and running into issues getting IPv6 to show up in Webfig. IPv6 is enabled and usable from the CLI, but nothing shows up in Webfig. I need to provide techs access to make changes and webfig works best for us to do that. Is there something that needs to be done to get the IPv6 tab to show up in webfig. Also noticed on this box after disabling PPP and Wireless packages, that those settings are still available in webfig. Running 6.37.2.
Thanks in advanced.
In Webfig use the Design Skin to add or remove menu options. You can also create multiple skins and assign them to different user groups if need be.
I checked that and everything is already checked in ‘Design Skin’. IPv6 tab does not exist in the Design Skin page either.
Does Webfig need to be reloaded some how to check what packages are installed? The router has been restarted twice.
The IPv6 should be visible when you enable the package and restart.
Are you using a current ROS version? I believe IPv6 was added to Webfig much later after it was available in CLI and Winbox.
It did not show up after enabling the package and Wireless and PPP did not disappear after I disabled their package. It seems as if Webfig is not reloading after packages are changed.
I am running 6.37.2, so only behind by one minor release.
I did just notice this in the release notes for 6.38rc45. Maybe it is a bug after all.
*) webfig - show ipv6 addresses correctly;
Possibly, I am on 6.38rc40 and tested on a RB2011 and it worked as expected.
Thanks. I will run 6.37.3 tonight and see if it helps. If not may go back to 6.36.4 stable. Any known issues with going back?
Same here, I’m on a Hex RB750Gr3.
I enabled ipv6 package but it’s not showing up in webfig nor in design skin even after restart.
I have to use winbox to see the ipv6 menu.
Hello to everyone. Because i have the same problem with an CCR1072-1G-8S+ (RouterOS 6.44.3) here and nobody has answered or resolved this issue, i have contacted the support.
For me, the explanations from there help quick and precise.
Here the answer from mikrotik support:
Have you tried to clear your browser cache or try another browser?
Hope it will help anyone and reduce support requests
Sincerely
