webfig is dying after every reboot.
I purchased the RB5009 and am using it with the default settings.
Initially, it was giving incorrect IP addresses from Class A to Class D to connected Linux machines.
That would be fixed for a while with a reboot, but webfig would continue to cause problems.
When I go to webfig, everything seems fine for a while, but after a while, the terminal and quick set stop working.
Also, on the webfig screen, I can see the menu on the left, but when I go into the menu, the items disappear one by one.
When this happens, I am unable to log back in, and my internet is disconnected.
I’m not sure if it’s a hardware issue or a firmware issue.
Has anyone had a similar experience to mine?
Translated with www.DeepL.com/Translator (free version)
Aditionally, i tried to solve this problem by serveral ways, update firmware, factory reset. but it does not work.
Please remove the spam link on first post.
You have not provided ANY relevant information.
And it’s also the first time someone has reported it.
