hello there
i used dynu.com to remote access and mange my mikrotik server winbox work okay but webfig no
my mikrotik configuration :
1- i used 2 lines ( load balancing via PCC )
2- all / ip services : allowed
my ADSL router configuration
1- port open 8291 for winbox
error msg i get when i try to access webfig via firefox :
If you trust the ISP’s and datalinks in between you go for it. I would at least make the external port different than 80 though to obfuscate (And in case you have an actual http server that needs that port).
a) webfig can use SSL, just enable it.
b) webfig doesn’t use java
c) you should use the built-in dyndns (ip->cloud) to simplify your setup
d) use WinBox when you can, it’s much faster than WebFig
