Webfig Skin broken by BUG
Hello.
After struggling many days with skins to make it work i figure out what is happening.
My problem is that when i hide some elements the skin is broken and goes back to default.
I found that this is happening when you make any change to system>script>Don’t require permissions!
json file recognizes this->` character as start and end of command description with the result being like this:
Normal behavior: Reset Configuration: 0,
Broken skin: **‘Don’**t require permissions’
I have no idea how WebFig skins work. I’ve never used WebFig (I am not a masochist :stuck_out_tongue: ).
But you may try escaping single quotes.
'Don\'t require permissions'
It’s still exist. When you done any manipulations wit this filed - it crash the skin and after relog - skin return to default.
