Since v5.4 we have a new feature in Webfig - “Design Skin”. Click this button to make changes to the Webfig interface. This is perfect to remove unnecessary features for RouterOS users who don’t want to see them, to make it easier to find what is needed to this specific user, or to hide things he could “break”. Also great for translating the entire interface!
How to make a skin
Log into Webfig:
Click “Design skin” button:
You can now uncheck any element to hide it, you can rename any element or translate it:
You can also add limits to text fields, add notes or make fields read-only:
Once you SAVE the skin with a new name, and exit the Design mode, you will see the changes:
Go back to full skin mode with the Design Skin button, and go to the System Users menu to assign this skin to a specific user group (probably make a new group). To hide the “Design skin” button from this group, uncheck the “policy” checkbox:
Once again, this is not a security measure, as skilled users will be able to overcome these applied limitations.
