Webfig: upload files into flash
Please, do anyone know, how I can upload files by webfig into /flash folder on devices with SPI? Or how can I move files into /flash from / using CLI?
So the summary question is how to put file into flash without winbox and fetch?
Unfortunately at the moment this is not possible. You have to use fetch to move file or use actual FTP connection to device.
Thanks for answer. Are you planning to add this feature in future releases?
