Webfig woes
Hi all.
I am having problems with Webfig main screen (aka “QuickSet”) “Local network” section.
To which interface are those data related to?
At the moment I see the data for eth4 but, if I simply hit “apply configuration” button that configuration is applied to eth2.
If this is not a bug I am missing some important bit of information.
What is your experience?
My experience says that it is better not to use quickset at all but start with wiping the config and make the configuration manually from scratch. But you have to have some knowledge of course.
