webfig is not to connect to any other router, it’s for connecting to the router where webfig is present. it’s not a separate application, it’s built into RouterOS.
Every time then I try to connect to http://demo2.mt.lv/webfig/ via Google Chrome I get error page
ERROR: Router has been disconnected (Reconnect)
After I press “Reconnet” button i can successfully login.
Normis,
I need a simple web interface for costumers using. I want to show them only few parameters (like wireless signals), but is important for us to hide other options.
Today the only way is write a special software, but is more simple (and better) to have a customizable web interface.
Will you be able to reorder fire rules? The last webfig I tried did not have the option to move firewall rules. If you made a new rule, it put it at the bottom of the list, and support told me there was no way to move it with webfig at that time.
Why don’t you give the full info? It is just hiding options, but it has nothing to do with user privileges. Users stil can access all options if they know how to, or simply by using Winbox.
Why don’t you simply improve privilege system, so we can realy disable options for users, as requested years back?
Ah, I see the problem now. The drag thing doesn’t work on an iPhone, which is the only situation where I ever use Webfig. It works fine on PCs and Macs, but when I have one of those on hand I always use Winbox.
