I have a new MT from Windwireless. I keep getting an error when I try to log in with webmin. It locks up with the following error. Connecting to port 8291.
What is the fix for this problem?
Webmin? It is tool not designed for MT. Don’t you think winbox?
U can use winbox http://ur router ip/winbox/winbox.exe this will install winbox for you.
Or on v2.9 you have WebBox tool
