webproxy is not workinkg
hi
transparent webporxy is not working on 3.0rc5 pl check out
I have ROS 3.0RC5 and transparent proxy works fine, even better than ROS 2.9.xx
Post your configuration here.
it is working when u are using nat but with bridge is not working ok
agian pl check the menu u wiil see two bridge option ok.i think there is problem with bridge.pl check out
If you have two bridge in your menu, you must have installed the “stpbridge-legacy” package. Uninstall it in system/packages and reboot the router.
skillful good man is working now thanx.
