How to enable WebProxy LOG. I want to store it remotelly.
As far as I remember, we have discussed that already,
‘system logging add action=remote topic=web-proxy’ (or topic=web-proxy,!debug’),
‘system logging action set remote remote=’ - to specify remote logging server.
Of course correct configuration is necessary at the remote logging server.
yeah but how can read the logs where are they stored ?? i mean if i want to read old logs where can i go ?
Well, in this topic we are talking about the remote syslog server, that means you may find old logs at syslog server, in the place where you have stored them.
How to Disable the Embadded Proxy.
I have tried but still its NOT working
If you are talking about HotSpot proxy, then ‘ip hotspot user profile set profile_name transparent-proxy=no’.
i think you can use syslog daemon from MT.
Point the logging (/system logging) to the ip address where you have the syslog daemon, port 514 .
DOne it before, but the problem is the log in syslog couldn’t save by it self automatically, so everytime the pc reboots, it clear everything. Unless we exit the syslog, then it’s saved. CMIIW
Regards,
Me
Yes, you may use either syslog from MikroTik or use any other syslog (that probably provides more advanced options).
actually the Dude can also work as a syslog and gather your logs
How do you set it up with the dude?
Regards
Leon
