Hi everyone,
I’m running ROS 4.10 on a PC based Mikrotik router.
I have the webproxy enabled with the mangle rules set for the redirect and everything is working fine.
The problem I am having is that when a customer does a speedtest from speedtest.net it appears that the pings it performs to get ping time are going through the webproxy and report way slower times than they are actually getting.
Has anyone else encountered this problem?
I know it’s the webproxy because when I disable it the ping times are reported correctly.
I’m really not sure where to start to fix this.
I would greatly appreciate any suggestions anyone could give me.
Okay maybe I wasn’t clear enough
I have 1 RB433 with an XR2 card in it.
I am testing it with one client connected.
With the webproxy turned on and working correctly I can go to speedtest.net and run a speed test and the pings show around 240ms because they are somehow going through the webproxy.
With the exact same client I can disable the webproxy and go to speedtest.net and run a speed test and the pings show the appropriate under 3ms.
Has anyone had this happen before?
How would I go about discovering how to fix this?
One more thing, it is all speed test sites, and it is only speed test websites.
When I initiate and normal ping from command prompt it shows the correct ping times.
I try it both with my internal DNS servers and external sites like yahoo, google, etc… and they report the correct under 4ms ping times from a command prompt.
I have the same problem; speedtest.net report 200-400ms a connection that in reality has 40-50ms tested with pingtest.net. I think is not webproxy fault.
