[webproxy-test bug] <base href="http://url/" /> gets trimmed
Hello.
I’m using webproxy-test under 2.9.45 and I have a small issue with a website and probably with others.
Try visiting http://www.upc.ro when the webproxy-test is enabled and set as transparent proxy. Nothing loads up. Not the images, not the javascript, not the css and links don’t work. Upon disabling the srcnat rule in the firewall (thus having direct access to the web) the website works fine.
Later edit: it seems to have an issue with the tag…
When the proxy is enabled I get , while the correct tag in the page is .
So where do I post a bug, seeming that here nobody notices the bug posts?
Is this thing actually getting noticed?
can you try ROS v3 RC6?
Contact support (support@mikrotik.com), in case you think that you have found bug at RouterOS.
Can’t try to use RC6 on that particular box. It’s our main gateway and I don’t want to risk breaking internet access for all our customer. I’ll try and see on another box.
This is confirmed under version 3.00 RC7 too.
