Hi
I am having a problem with the proxy - It keeps loosing the proxy port - i have set it to 8080.
Is there any way to fix this.
Regards
Malcolm
Hi
Regards
Malcolm
what RouterOS version? did you configure the port within winbox or from telnet? how long did your configured port work before it changed ?
Hey
I am using ver 2.9.6 Routerboard 532
I am using a gateway failover - when the gateway failed over the HTTP proxy stoped working
Any ideas
Regards
Malcolm
how about the rest of the questions that I asked ?
Hi Sorry
I used Winbox to configure it - it probably worked for about 2 days failing
Regards
Malcolm
