webproxy troubleshooting
Hello everybody
I got this problem:
I use firewall to block access to the router from the Internet and my proxy does not work.
so I have found a solution
Make sure you allow established TCP connections with tcp option ‘non-syn-only’ to the router before blocking everything else. In v2.5, the rule is like this:
‘/ip firewall rule input add protocol=tcp tcp-options=non-syn-only connection-state=established’
but, can somebody tell me how can I set tcp-options=non-syn-only in routerOS v 3.7 ???
maybe Im too stupid for this :open_mouth:
thx lot
somebody help please …
24 reads and no reply ???
What about this?;
/ip firewall filter add chain=input protocol=tcp tcp-flags=!,syn etc
still dont work :frowning:
I have tried this:
tcp-flags=!,syn
tcp-flags=syn
tcp-flags=!,ack
tcp-flags=ack
tcp-flags=!,urg
tcp-flags=urg
tcp-flags=!,cwr
tcp-flags=cwr
dont know about other but I think there wont be difference
