Hi
i need help regarding following senerio on RB450G i have clients configured to use pppoe also created vlan from 11-15 and enabled dhcp for each vlan
vlan and pppoe config are working fine i want my users to communicate with webserver without going through router interface i have also created a vlan 100 for webserver
Vlan100
172.16.100.100 = webserver
when client pc enter’s 172.16.100.100 in his web browser i want my clients request to go directly to 172.16.100.100 what should be the configuration to access webserver without going through my router interface my network design is below
You can’t. VLANs are layer 2 broadcast domains. To leave a layer 2 broadcast domain you need to go through a layer 3 interface that can route traffic between broadcast domains. In your case that layer 3 interface resides on the RouterBOARD, so traffic must pass through it.
i did created all the vlan’s on cisco everything works fine until i dial pppoe and get pppoe ip on client machine after that when i enter my webserver ip on web browser my request goes directly to my RB. is there any configuration i shud do on my RB ?
before dialing pppoe dialer i can access my webserver directly cisco is routing request directly but after pppoe it’s going directly to RB what i m missing please guide.
Once you start the PPPoE client the customer will have a default route through the PPPoE server on the Mikrotik router.
Why is it so important to you that traffic doesn’t go through the router? What are you actually trying to achieve?
Does it have something to do with trying to exempt traffic to that server from rate limits?
it’s important because i dont want my clients to limit on given taffic bandwidth over pppoe and want them to directly access any local machine on vlan100 i m planning to add game servers also so that would be a problem if it goes through RB interface
Again, those override the existing simple queues for traffic that matches, and will rate limit traffic to and from the web server at 1Gbps, which is line speed. If you add more services just add the hosts to the address list.
This was written away from any router so it is off the top of my head, and there maybe errors in that. The theory works, though.
In the network layout you have you cannot avoid going through the router. But you can work around the rate limit problem.
You can take this further and use RADIUS authentication for PPPoE and use dynamic address lists and do away with simple queues completely, and do everything manually and customize your rate limiting. But that may be overkill for you at this moment.
i have done this in queue tree but after transfering data over 20mbps RB goes timedout and client cant even browse wesite’s while downloading some movie from local webserver.
thats also a problem is there any other possible way that local addresses shouldnt go through router interface after dialing pppoe or there’s any other configuration that i should do in Cisco [L3 Switch] or is there any other hardware that should help in this scenario?
