website blocking
Hi Everybody
I have a RB750GL and i want to know how to block all websites except for google…
tanks in advance
Hello
you can use webproxy for your solution.if you need i can send an example for you.
I’m looking for almost the same. My difference is that I want to block most websites only for some specific computers.
Is Webproxy a component of Mikrotik? I didn’t find it on Winbox…
until now. It’s located under the IP menu.
Unfortunately, it doesn’t seem to be as useful as I wanted.
My purpose (maybe similar to mr. christianbas’) was to block any domain name on some computers, except for our Google Apps domain.
Mikrotik automatically converts the domain name to its IP, which is just one of many, in the Web Proxy rule.
Any native way to block websites at their domain level (not at IP address)? Or should I search out from Mikrotik/RouterOS?
Thank you beforehand.
OK.you can do this in webproxy.you can filter domain names in webproxy for any src-address you want.
How do I input the domain name, may I ask?
As I said: through Winbox, the name is automatically converted to its IP address.
I just tested through Webfig, but it doesn’t accept text strings at all.
And I’m not able to figure out how to get or set an item through SSH. -_-u
I would like to see your example, as well.
The problem with using web proxy is that it doesn’t block https. So if the site has an https version web proxy is useless.
