Website Domain
I have a domain pointing to my IP. I run a web server behind RouterOS. Anyone outside of the network can access the site just fine, but if anyone behind routeros tries to use the domain to access the site, they get the routeros web admin page.
How can I configure routeros to make it so when people from inside my network try to use that domain they get my webserver?
My external IP is dynamic by the way.
post your NAT and IPs configration
how would I do that?
in CLI
ip address export
 ip firewall nat export
and post output
[admin@MikroTik] > ip address export
# may/19/2008 16:55:34 by RouterOS 2.9.26
# software id = ILTS-NX0
/ ip address
add address=192.168.2.1/24 network=192.168.2.0 broadcast=192.168.2.255 \
    interface=ether3 comment="" disabled=no
add address=192.168.1.2/24 network=192.168.1.0 broadcast=192.168.1.255 \
    interface=ether2 comment="" disabled=no
[admin@MikroTik] > ip firewall nat export
# may/19/2008 16:56:07 by RouterOS 2.9.26
/ ip firewall nat
add chain=srcnat out-interface=ether1 action=masquerade comment="" disabled=no
add chain=dstnat in-interface=ether2 action=netmap to-addresses=192.168.2.100 \
    to-ports=53-80 comment="This is for fake_net" disabled=no
add chain=dstnat protocol=tcp dst-port=56671 action=netmap \
    to-addresses=192.168.2.201 to-ports=56671 comment="emule TCP" disabled=no
add chain=dstnat in-interface=ether1 protocol=udp dst-port=6959 action=netmap \
    to-addresses=192.168.2.201 to-ports=6959 comment="emule UDP" disabled=no
add chain=dstnat in-interface=ether1 protocol=tcp dst-port=80 action=netmap \
    to-addresses=192.168.2.100 to-ports=80 comment="web server" disabled=no
add chain=dstnat in-interface=ether1 protocol=udp dst-port=88 action=netmap \
    to-addresses=192.168.2.60 to-ports=88 comment="" disabled=no
add chain=dstnat in-interface=ether1 protocol=tcp dst-port=3074 action=netmap \
    to-addresses=192.168.2.60 to-ports=3074 comment="" disabled=no
add chain=dstnat in-interface=ether1 protocol=udp dst-port=3074 action=netmap \
add chain=dstnat in-interface=ether1 protocol=tcp dst-port=445 action=netmap \
    to-addresses=192.168.2.100 to-ports=445 comment="" disabled=no
add chain=dstnat in-interface=ether1 protocol=tcp dst-port=135-139 \
    action=netmap to-addresses=192.168.2.100 to-ports=135-139 comment="" \
    disabled=no
add chain=dstnat in-interface=ether1 protocol=udp dst-port=135-139 \
    disabled=no
add chain=dstnat in-interface=ether1 protocol=udp dst-port=445 action=netmap \
add chain=dstnat in-interface=ether1 protocol=tcp dst-port=38565 action=netmap \
    to-addresses=192.168.2.100 to-ports=38565 comment="" disabled=no
add chain=srcnat out-interface=ether2 action=masquerade comment="" disabled=no
what is your server IP, and also what interface is WAN and what is LAN
Ether1: dynamic IP - Internet (WAN)
Ether2: 192.168.1.2 - LAN
Ether3: 192.168.2.1 - LAN
I am only concerned about the Ether3 lan and the WAN being able to access it though.
and your server on Ether2 or Ether3 and what is it’s IP
Server is on Ether3, 192.168.2.100
delete your web server nat role and add below
add chain=dstnat protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.2.100 to-ports=80 comment="web server"
and change your router WWW server from 80 to any other port
Changed www service to port 81 … Still doesn’t work ..
External addresses can still access it, but I get “connection timed out” from internal attempts.
From what I gather…
If your desktop is also on Ether3 you can not route back to the same interface from which you came. The linux kernel will not allow you to do that.
Yea, my desktop is on ether3 … so does that mean I can’t fix this problem?
UPDATE: I fixed this issue by making a static DNS entry for my domain to my local server. This will work for anyone else also who has this problem as long as their users have their DNS pointing to your routeros. If not, then you will just have to put this static DNS entry on whatever DNS server they do have theirs point towards.
