IMHO, if the scripts are already made, it’s not at all difficult to use WebFig, and go to the “System > Script” menu to run them.
But if you want something sleeker… On the router itself, there are two ways:
Reverse engineer WebFig, then after creating a hotspot (to serve as the entry point), customize the hotspot page with the reversed engineered WebFig.
Pro:
Less taxing on the router (compared to the other method)
Con:
Difficult to pull off, very error prone, and unstable across version changes.
Install a Linux on a KVM/MetaRouter virtual machine, and create a web application that will use the API protocol to connect to the real machine, and invoke the desired script (or whatever else you might want to customize…).
Pro:
Not so error prone (in that it’s easier to detect errors), easier to make the app… Once you set up the VM (which is the difficult part).
Con:
Very taxing on the router, particularly with RAM. You need enough to run the router + enough to run the VM + enough for its web server and whatever else you may need on the VM.
If you can live with the web application not being on the router itself, there’s also a 3rd way: An API application (same as approach 2), but on a separate, real machine. This is least taxing on the router, but it means there needs to be internet connectivity for your web interface to work.
