Hello dear humans,
Recently I have experienced weird problem with Mikrotik hardware.
I don not know if it is hardware or software issue, but I think,
the configuration is basic and I have tested it at home.
Hardware:
1 x Mikrotik RouterBOARD 433
2 x WiFi cards
1 x Power adaptor 24V 0.8A
1 x Simple switch
1 x PC server
Config:
WiFi users --bridge1–> Mikrotik --ehternet2–> Switch ----> PC ----> Internet
Interface “bridge1” on Mikrotik has both WiFi card (wlan1, wlan2) and “ehternet3” interfaces included.
DHCP runs on the “bridge1”. The gateway and dns for WiFi is Mikrotik. DNS redirects to PC.
Default route for Mikrotik is PC.
Addresses are
WiFi users ← 192.168.2.0/24 → [192.168.2.1]Mikrotik[192.168.1.2] ← 192.168.1.0/24 → [192.168.1.1]PC[...] <----> Internet
Firewall rules are absent.
As I said, configuration is very basic and worked at home.
We put it onto 40-meter tower and connected 2 antennas.
The temperature is below 0, about -10C.
First, I wanted it to handle 3 WiFi cards which would be wired with 3 antennas but
this caused problems connecting to any of WiFi networks (wlan1, wlan2, wlan3).
Then, I wanted it to handle 3 antennas with 2 WiFi cards but
every time we switched on the third antenna, nothing could connect to “wlan1” or “wlan2”.
We tried different RouterBOARD_433 cards with different WiFi cards.
We tried different versions of RouterOS (v3.30, v4.16)
We tried all possible wifi settings with bridge and without bridge.
WiFi users have CCQ=90-100%
I measured AC (~240V) and DC(24V) voltage, it seems to be alright.
The result is weird.
Sometimes, it connects, sometimes not (wlan1, wlan2, ethernet3).
When we first had put it, it worked, now it doesn’t.
Mikrotik pings internet servers.
Wifi user successfully gets IP from DHCP, resolves names, and pings PC server..
but when the connection is made to internet server, it hangs up. In the IP->Firewall->Connections it’s said “syn sent”..
Please help, I have no ideas.
It’s cold in here :]
