I’m facing strange issues with connection tracking on a RB2011.
Running ROS 6.6
Connection Tracking is set to Auto.
I have no FW-rules at all. But it’s still tracking connections. ![]()
/ip firewall connection tracking> print
enabled: auto
tcp-syn-sent-timeout: 5s
tcp-syn-received-timeout: 5s
tcp-established-timeout: 1d
tcp-fin-wait-timeout: 10s
tcp-close-wait-timeout: 10s
tcp-last-ack-timeout: 10s
tcp-time-wait-timeout: 10s
tcp-close-timeout: 10s
udp-timeout: 10s
udp-stream-timeout: 3m
icmp-timeout: 10s
generic-timeout: 10m
max-entries: 220920
total-entries: 98
even if i’m turning off the tracking manual its showing total-entries.
anyone an idea which setting can cause such behavior?
enabled: no
udp-timeout: 10s
icmp-timeout: 10s
max-entries: 220920
total-entries: 104
On an other ROS device (RB750GL) here in my lab it behave like expected: only tracking as soon it has one enabled fw-rule. if i turn tracking manual off it shows 0 total-entries.
/ip firewall connection tracking print
enabled: auto
udp-timeout: 10s
icmp-timeout: 10s
max-entries: 90968
total-entries: 0
