Weird DNS problem...
Hello everyone, I’ve been trying to route traffic through 2 LTE interfaces so I followed a guide online and created the following Address Lists
add address=10.0.0.0/16 list=PrivateIPAddresses
add address=192.168.0.0/16 list=PrivateIPAddresses
add address=172.16.0.0/12 list=PrivateIPAddresses
and the following mangle rules
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address-list=!PrivateIPAddresses
in-interface=bridge new-routing-mark=lte1.fake passthrough=no
in-interface=bridgeClients new-routing-mark=lte1.real passthrough=no
The weird thing is that I couldn’t get the lte1.fake to work… I could ping but the DNS didn’t work at all…
What I found out, is that I made a “typo” on one of the address lists, what I wrote was:
add address=192.168.0.0.16 list=PrivateIPAddresses
Can someone please explain to me what I wrote, I mean what is 192.168.0.0.16??? Should routeros stop me from writing something foolish like that, or is it something that I’m just not aware of?? (my quess is the second!!!)
Thanks in advance :slight_smile:
Yeah that odd… But what’s going on is 192.168.0.0.16 becomes a string, so address-list thinks it’s DNS lookup. And DNS lookups in address-list are valid, so it allows you to add with what you think is an invalid address= but to RouterOS is a DNS query for “192.168.0.0.16”
IMHO it means: server named “192” in the “168.0” subdomain of “0.16” domain.
Yes, that is how it is handled. A bit more prudent would be to require at least one letter in the name before it is handled as DNS lookup.
True, the number be valid (e.g. in-addr.arpa), so it just the top-level that isn’t checked… But…then again it matches /ip/dns/static logic: that’s allows defining an all number domainname in an A record (name=192.168.0.0.24).
Even more prudent…be have some “status” to know the DNS lookup failed. e.g. using “bad.gooogle.coom” also doesn’t show any error – but I’ve run into fat fingering a domain name myself before – only visual clue is address-list doesn’t populate any dynamic entries…
You seem to do that a lot. :confused:
Thanks for all the replies, as always, I am wiser thanks to you!
