Weird issues with the RB951G-2HND
I have been encountering some issues connecting my Android Tablet (an Acer Iconia One 8 running Android 5.1) to a network with the security set at WPA2-AES (no TKIP). For some reason, it will complain of WiFi connection/authentication issues and not connect to the network every now and then (which a reboot of the router fixes). Also, I am getting disconnected from the network every so often until I set a static IP, etc. Can anyone help figure out the cause of both issues?
Hallo, you have to increase your dhcp Server Time out Session, i think it’s by default 10 Second .
Best regard
Gesendet von iPhone mit Tapatalk
Thanks for letting me know. And, its not 10 seconds, its 10 minutes (It goes in the order of hours:minutes:seconds). I changed it to a day and will see if that fixes either or both issues.
You Are welcome and let me know if it help
It fixed both issues.
