SO i’m trying to do a LACP Between a Mikrotik and the Switch Module of a Cisco 2851 Router to aggregate data between some ports.
Issue I am having here is that the Bonded Interface Comes Up However I am only getting Rx Traffic on One Interface but Tx Traffic on both interfaces.
SHO LACP NEIGHBOUR
Flags: S - Device is requesting Slow LACPDUs
F - Device is requesting Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
Channel group 2 neighbors
Partner's information:
LACP port Oper Port Port
Port Flags Priority Dev ID Age Key Number State
Fa1/0/44 SA 255 0060.e04a.6c03 20s 0x9 0x1 0x3D
Fa1/0/45 SA 255 0060.e04a.6c03 20s 0x9 0x2 0x3D
Bonding is setup like so:
0 R name="bond_Routed" mtu=1500 mac-address=00:60:E0:4A:6C:03 arp=enabled
slaves=ether5 - Bonding Connection To Internet,ether6 - Bonding Connection
To Internet
mode=802.3ad primary=none link-monitoring=mii arp-interval=100ms
arp-ip-targets="" mii-interval=100ms down-delay=0ms up-delay=0ms
lacp-rate=30secs transmit-hash-policy=layer-2-and-3
This LACP is a Layer 3 Port Channel, However I have another group 1 that is on a switchport between the same two devices that works as expected.
this is one problem with proper 802.3ad from what i mostly see - its a per-flow kind of load balance means at best you might get a 70/30 balance, and a single stream always only 1 link worth. Mikrotiks own balance-rr gives proper bonding in my eyes, yet to get Mikrotik + Cisco doing good proper load sharing+bonding. I still use it though as it does split it a bit, and lets me lose a port/cable in failrue without losing the whole link.
I know this post is a bit old but would anyone be able to provide a working solution for creating a LAG between a Mikrotik and a Juniper router that actually works?
I’m really struggling to use a CCR1009-8G-1S-1S+ with its 1 x 10g and 1 x 1g fibre ports in a LAG. Traffic flows over the 1g, but not on the 10g. 10g port is forced to 1g (with a 1g SFP) and part of a bonded interface.
No matter what I do, the Juniper just does not want to bring the sfp+ with the 1g interface up.
Does this work with this model CCR?
Mikrotik sees it as up, but I dont think the LACP packets are getting to the Juniper…
show lacp interfaces ae1
Aggregated interface: ae1
LACP state: Role Exp Def Dist Col Syn Aggr Timeout Activity
ge-1/0/3 Actor No No Yes Yes Yes Yes Slow Active
ge-1/0/3 Partner No No Yes Yes Yes Yes Slow Active
ge-1/0/4 Actor No Yes No No No Yes Slow Active
ge-1/0/4 Partner No Yes No No No Yes Fast Passive
LACP protocol: Receive State Transmit State Mux State
ge-1/0/3 Current Slow periodic Collecting distributing
ge-1/0/4 Defaulted Fast periodic Detached
