weird message
on the Ap Bridge side (rb600a):
wlan1: lost connection, not polled for too long
wlan1: failed to connect, on 5800, recived deauth: class 2 frame recived (6)
on the Station WDS side (rb333):
wlan1: disconnected, extensive data loss
wlan1: connected, wants WDS
wlan1: data from unknown device xx:xx:xx:xx:xx:xx, sent deauth
where xx:xx:xx:xx:xx:xx is proper MAC address of the second device.
CCQ 100/100, 54/54 TurboA (also tested 48/48 and 36/36 with no results)
MT 4.9
what means: “not polled for too long”
any ideas?
try to increase the hw-retries count that might help in your case.
Hi uldis,
can you please explain why this setting should be increased to fix the problem? I also have that problem with one client that disconnectes within some days. Others clients stay connected.
The AP just shows a “extensive data loss” while the client shows “not polled for too long” .. i am using nstreme with exact-size and wds
Best regards ans thanks,
Joerg
