I’ve followed this guide to installing RouterOS in GNS3 using QEMU.
http://brezular.com/2014/07/09/running-mikrotik-routeros-x86-on-gns3/
My installation is in Windows, but I got it running very easily and it’s fantastic to have Mikrotik in GNS3.
I’ve found two issues and I am wondering if anyone else has seen such a thing:
I set it up to have 5 ethernet ports. The mikrotik sees all 5 ethernet interfaces, but strangely, e3 / ether4 (qemu/mikrotik view) can’t receive traffic. It sends just fine.
If I snoop the interface with wireshark, I see CDP from two Mikrotiks I connected to a switch. I also connected a cisco router to the switch, and it sees both Mikrotiks when I do “show cdp neighbor”
The 'tiks are just deaf on ether4 - they can use ether1-3,ether5 all day long.
The second thing - qemu is dropping the 802.1q vlan tags from packets on egress, and discarding any tagged frames on egress. (Mikrotik does not see the traffic at all)
I think it’s the NIC driver rtl8139, which from some gooling I did on the qemu forums, this appears to be a driver issue, and I should try e1000 but this crashed the mikrotik image.
Anyone have similar issues as these?
(I’ll post updates if I find solutions on my own)
