Weird OSPF route redistribute behavior
Hey guys,
I noticed some weird ospf redistribution behavior yesterday, and I’m trying to find out if it’s a bug, feature, or just the way MikroTik has programmed things, and if it’s going to change in the future, or what’s going on.
  1. A blackhole route is getting automatically pushed into OSPF, regardless of route filters, and redistribute rules being checked in OSPF Instance. If I put in a blackhole route, and if there’s no specific filter, even if there is an out-filter selected, in the instance, but the subnet isn’t in the out-filter, that blackhole route is being redistributed in OSPF, and everything under redistribute is unchecked.
  2. Everything under “Redistribute” is unchecked. I have a Public IP on a vlan, a /30. That vlan is not on an interface under Interface templates. That /30 is getting redistributed into OSPF because the entire /22 of that Public IP block is in the OSPF route filters. If I was to remove the /22 from the route filter, the /30 will go away.
This doesn’t seem to be normal, but maybe it’s normal for MikroTik? Any ideas?
Can you post your route filter rules?
It sounds like you are accepting “dst in x.x.x.x/22” which will also match more specific prefixes inside that /22. You can either switch to something like “dst == x.x.x.x/22” if you only want to match that specific /22, or you can match a specific range of prefix lengths with something like “dst in x.x.x.x/22 && dst-len<24”.
add chain=ospf-out comment=“All Public IP’s” disabled=no rule=“if (dst in 38.141.40.0/22 && dst-len in 0-32) { accept; }”
So this is where that rule is “dst in” instead of “dst ==”
“dst in 38.141.40.0/22 && dst-len in 0-32” will match any prefix inside 34.141.40.0/22, such as 34.141.1.0/24 and 34.141.41.4/30 for instance. That is the normal expected behavior. You can change it to “dst == 38.141.40.0/22” to only match that exact prefix and no other more specific prefixes inside of it, or you can change it to something like “dst in 38.141.40.0/22 && dst-len in 22-24” to also match the /23 and /24 prefixes inside that /22, but not any /25 or longer prefixes.
