Weird performance on CRS309-1G-8S+ R2
I describe first what I have and later the issue:
List
Switch CRS3090-1G-8S+ R2 Firmware Swos: 2.16
A mix of 4 1 GB S+R1 Transceiver and 4 10GB s+RJ10 Transceiver (R2)
  • Fiber Modem
    • Draytek 2962 using 2.5GB to Mikrotik
    • Laptop connected to Draytek
    • Mikrotik connected to Draytek (10GB)
        • PC connected to Mikrotik (10GB) Using a Qnap AQC107
          All devices are uptated to the latest firmware. Windows is also update to the latest of Windows 11-Pro
Problem description
If I copy an iso file from the pc to the laptop it passes the Mikrotik and Draytek and has a speed of 900mbps
The other way around also 900mbps.
If I do a speed test on the pc and it is passing the Mikrotik, Draytek and Fibermodem I read this:
Download 850/950 mbps
Upload 450mbps.
  • If I unplug the PC from the 10GB transceiver and plug the cable into a 1GB transceiver, the download 900mbps and upload are 900mbps. during the speedtest.
If I do a speed test on the laptop and it is passing the Draytek and Fibermodem I read this:
Upload 900mbps.
So I woder why is the uploadspeed to the laptop so much higher than the speedtest download?
Is it the transceiver? I tested 2 out of 4 transceivers and they all say 900 down and 450up.
Greetings,
RobB
