device 1
[admin@dev1] > /export hide-sensitive
# sep/20/2020 16:49:28 by RouterOS 6.47.3
# software id = DBKU-GQIG
# model = RouterBOARD LHG G-5acD
# serial number = 80B9077C1887
add name=bridge1
set [ find default-name=ether1 ] speed=100Mbps
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=xxx \
supplicant-identity="" unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2 antenna-gain=0 band=5ghz-a/n/ac basic-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
channel-width=20/40/80mhz-Ceee country=no_country_set disabled=no distance=3 frequency=5360 frequency-mode=superchannel ht-supported-mcs=\
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 mode=station-bridge scan-list=5360 security-profile=xxx ssid=NOD10-AC_FORCE station-roaming=\
enabled supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps vht-supported-mcs=mcs0-7,mcs0-7,mcs0-7 wmm-support=enabled wps-mode=disabled
/interface wireless nstreme
set wlan1 enable-nstreme=yes
/ip hotspot profile
add name=dhcp ranges=192.168.1.10-192.168.1.250
/port
set 0 name=serial0
/routing bgp instance
set default disabled=yes
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge1 hw=no interface=ether1
add bridge=bridge1 interface=wlan1
set discover-interface-list=discover
/ip settings
set accept-redirects=yes accept-source-route=yes allow-fast-path=no route-cache=no
add interface=ether1 list=discover
add interface=bridge1 list=discover
add interface=ether1 list=mactel
add interface=ether1 list=mac-winbox
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
add address=192.168.20.254/24 interface=ether1 network=192.168.20.0
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
add address=192.168.20.254 name=router.lan
add distance=1 gateway=192.168.20.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
/routing bfd interface
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=dev1
/system logging
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
/system watchdog
set automatic-supout=no ping-start-after-boot=0ms ping-timeout=10s
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
dev2
[admin@dev2] > /export hide-sensitive
# sep/20/2020 16:50:59 by RouterOS 6.47.3
# software id = PBMM-K38Y
# serial number = 8108072D6445
add name=bridge1
add name=mactel
add name=mac-winbox
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=dynamic-keys name=xxx supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] ampdu-priorities=0,1,2 antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=no_country_set disabled=no \
distance=3 frequency=5360 frequency-mode=superchannel mode=bridge scan-list=5360 security-profile=xxx ssid=NOD10-AC_FORCE station-roaming=\
enabled wireless-protocol=nstreme wmm-support=enabled wps-mode=disabled
/ip hotspot profile
/port
set 0 name=serial0
/snmp community
/user group
set discover-interface-list=all
/ip settings
add interface=ether1 list=WAN
add interface=wlan1 list=LAN
/interface wireless align
set receive-all=yes
add address=192.168.20.253/24 comment=NOD10_LAN interface=wlan1 network=192.168.20.0
/ip dns static
add address=192.168.20.253 name=router.lan
add distance=1 gateway=192.168.20.2
/ip service
/system clock
/system identity
set name=dev2
/system logging
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
/tool mac-server
