However, it seems there is a wrong detection of the terminal capabilities, making it impossible to see anything but the last line of every command output…
(which renders administration kinda difficult)
Is there something I can do to use this extension to connect to my router ?
I’ve been experiencing this issue as well. I’m afraid I can’t add much other than that. I’ve fiddled with the settings but so far I haven’t found anything that works.
I too am encountering this issue. Only started happening after a ROS update a few months ago. It makes it where you can only see the last line of the response.
