Weird torch traffic! LAN visable to WAN
Hi!
I am experiencing some weird issues at the moment, we have a setup as below:
On the RB750s we have the following NAT rule in place:
0   ;;; Network NAT
chain=srcnat action=masquerade out-interface=Port 1 - WAN
Whenever we run a torch on the on the RB1100 eth1 we are seeing the following traffic:
192.168.1.x/24 ranges and 10.1.1.x/24 ranges, this should be natted to the 1.1.1.2 address and 2.2.2.2 address.
If I connect behind one of the RB750 and browse the internet my local range IP is been natted to the correct public IP, I cannot figure out for the life of me why the RB1100 is seeing this local range traffic, any ideas??
One 750 connects to eth01 and the other connects to eth02, correct?
What is the WAN port on the 1100?
And that is just a typo that the 1100 and the 750 have the same ip. The 1100 eth02 is 2.2.2.1/30, right?
No “arp=proxy-arp” on the 750 ethernet ports?
Yes sorry that was a typo!
Both 750s connect to eth01 on the RB1100 after the switch, reason for this is we have several other irrelevant devices connecting also.
Arp on the interface is “enabled” not “arp=proxy-arp”
If both connect to eth01, then both need the eth01 subnet. How do you have the second router (2.2.2.2/30) set up in “/ip route”? How do you have the 1100 set to send 2.2.2.2 traffic out the 1.1.1.1 interface?
This would be my setup:
The 1100 eth1 would be 1.1.1.1/28
750 #1 would be 1.1.1.2/28
750 #2 would be 1.1.1.3/28
Both 750 default gateways would be:
add gateway=1.1.1.1
EDIT: Does your internet connection device (cable/dsl modem) connect to the switch?
What kind of traffic do you see in torch, which protocols?
Would changing the set up of the network as above sort the issue? I should of expanded the diagram slightly as to say we have other routes on the network connecting to the switch. We have several draytek routers connecting back to the RB1100 which are showing their WAN side IP only in the torch.
HTTP and HTTPS only, that’s the crazy thing. As when I browse the internet from behind the RB750s it public IP is resolving correctly.
It is going to cure part of it. You have three subnets showing on that interface (with torch) that shouldn’t be there, and one is the 2.2.2.x subnet. It is already assigned to eth02 in the 1100. That will cause some routing problems. If you have other devices on that switch, they should all be 1.1.1.x subnet. BTW, I use the 10.x.x.x and 192.168.x.x subnets for internal networks.
You can assign multiple ip subnets to that interface, but I recommend keeping it simple, especially if you are doing another NAT (srcnat or masquerade) at the WAN interface on the 1100. I route my networks rather than NAT.
Hey all,
May I jump into this conversation?
We are seeing a very similar problem on our network - internal IP’s showing up on the WAN side of the network, http and https only.
The LAN side of our network is dhcp. All our clients get a 10.25.x.x/16 ip address, all our gear (wireless client bridges) is on a 169.254.x.x/16 address (static assignents, not assigned by RouterOS)
On the WAN side of the network we have a block of 16 routable IP’s. We use masquerade for our regular clients, and one-to-one NAT for special case clients.
Torch on the WAN port shows 10.25.x.x addresses, and sometimes a 192.168.1.x address, which is really wierd as we don’t use that range for anything.
Is it our statically assigned 169.254 devices that are confusing the router?
Are you certain the traffic is originating inside your network? I show 10.2.x.x addresses on my ether1 port, and I have no 10.2.x.x networks on this device. But my ISP does have those ips on my wan localnet, and I can ping them.
/tool sniffer
set interface=ether1
start
(wait a minute)
stop
/tool sniffer host print
I’d have to check with my internet provider, but I don’t think it’s there ips, as they are the ones that contacted me about it. Apparently it’s confusing their load balancer to have my private IP’s on the WAN port.
MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 3.23 (c) 1999-2009       http://www.mikrotik.com/
[root@NICROS1] > /tool sniffer host print
 # ADDRESS         RATE                PEEK-RATE           TOTAL
 0 96.54.202.0     0bps/0bps           1072bps/1392bps     134/174
 1 94.255.219.0    0bps/0bps           0bps/1048bps        0/131
 2 4.2.2.1         0bps/0bps           464bps/1464bps      58/183
 3 98.137.49.1     0bps/0bps           26.1kbps/18.2kbps   8662/6738
 4 4.2.2.2         0bps/0bps           2.1kbps/2.8kbps     812/1239
 5 14.202.131.2    0bps/0bps           928bps/464bps       290/58
 6 209.53.200.2    0bps/0bps           472bps/600bps       413/525
 7 164.58.206.2    0bps/0bps           0bps/792bps         0/99
 8 124.0.222.2     0bps/0bps           0bps/464bps         0/58
 9 109.153.173.3   0bps/0bps           384bps/0bps         48/0
10 68.169.198.3    0bps/0bps           320bps/368bps       80/46
11 10.25.2.4       0bps/0bps           0bps/1160bps        0/188
12 190.139.94.4    0bps/0bps           384bps/736bps       184/138
13 209.205.94.4    0bps/0bps           60.3kbps/20.6kbps   18339/7060
14 212.251.113.4   0bps/0bps           0bps/384bps         0/48
15 204.239.42.5    0bps/0bps           8.5kbps/280.5kbps   4865/124407
16 95.215.62.5     0bps/0bps           352bps/0bps         44/0
17 88.91.83.5      0bps/0bps           0bps/384bps         0/94
18 193.173.27.8    0bps/0bps           1920bps/2.2kbps     480/276
19 81.98.54.8      0bps/0bps           0bps/760bps         0/95
20 10.25.200.8     0bps/0bps           0bps/416bps         0/156
21 68.196.25.9     0bps/0bps           0bps/792bps         0/99
22 184.98.76.9     0bps/0bps           744bps/1112bps      519/1103
23 78.63.29.10     0bps/0bps           0bps/464bps         0/116
24 209.170.69.10   0bps/0bps           352bps/368bps       84/46
25 201.45.104.10   0bps/0bps           464bps/0bps         260/0
26 213.146.188.10  0bps/0bps           7.0kbps/4.4kbps     1489/1067
27 84.46.236.10    0bps/0bps           0bps/760bps         0/95
28 218.212.251.10  0bps/0bps           0bps/1040bps        0/130
29 64.94.107.11    0bps/0bps           7.6kbps/3.3kbps     956/421
30 66.220.147.11   0bps/0bps           0bps/736bps         0/92
31 66.220.149.11   0bps/0bps           11.4kbps/3.1kbps    1465/398
32 213.146.188.11  0bps/0bps           5.2kbps/3.8kbps     932/750
33 173.74.213.11   0bps/0bps           1840bps/35.1kbps    3334/90622
34 74.70.208.12    0bps/0bps           488bps/0bps         61/0
35 161.69.12.13    0bps/0bps           320bps/0bps         40/0
36 96.6.40.13      0bps/0bps           488bps/752bps       61/94
37 64.94.107.13    0bps/0bps           5.4kbps/22.0kbps    679/2755
38 213.146.188.13  0bps/0bps           360bps/368bps       85/46
39 124.125.43.14   0bps/0bps           1312bps/848bps      1486/530
40 96.42.111.14    0bps/0bps           976bps/0bps         122/0
41 69.63.190.14    0bps/0bps           38.7kbps/9.9kbps    4838/1245
42 78.0.232.14     0bps/0bps           0bps/760bps         0/95
43 68.150.19.15    0bps/0bps           0bps/464bps         0/116
44 74.59.96.16     0bps/0bps           0bps/792bps         0/99
45 65.55.184.16    0bps/0bps           0bps/368bps         0/92
46 84.48.41.17     0bps/0bps           1072bps/416bps      287/196
47 74.125.53.17    0bps/0bps           17.2kbps/4.6kbps    4219/1191
48 74.125.127.17   0bps/0bps           320bps/0bps         40/0
49 83.31.215.17    0bps/0bps           0bps/1072bps        0/134
50 93.178.199.18   0bps/0bps           0bps/1072bps        0/134
51 94.29.49.19     0bps/0bps           0bps/1072bps        0/134
52 74.125.127.19   0bps/0bps           1280bps/1848bps     200/391
53 10.25.200.19    0bps/0bps           0bps/3.8kbps        0/1320
54 63.131.204.19   0bps/0bps           0bps/792bps         0/169
55 67.49.4.20      0bps/0bps           0bps/1048bps        0/131
56 15.174.109.20   0bps/0bps           528bps/0bps         175/0
57 66.151.151.20   0bps/0bps           256bps/0bps         96/0
58 178.30.177.20   0bps/0bps           0bps/512bps         0/480
59 69.80.36.21     0bps/0bps           0bps/464bps         0/116
60 96.6.40.21      0bps/0bps           1360bps/928bps      170/116
61 121.54.47.21    0bps/0bps           0bps/464bps         0/116
62 71.22.166.21    0bps/0bps           0bps/792bps         0/99
63 208.70.8.22     0bps/0bps           5.4kbps/3.1kbps     3420/1990
64 17.151.16.22    0bps/0bps           608bps/608bps       76/76
65 156.154.70.22   0bps/0bps           608bps/1560bps      207/461
66 156.154.71.22   0bps/0bps           536bps/3.7kbps      127/636
67 68.149.77.22    0bps/0bps           560bps/584bps       910/949
68 94.192.83.22    0bps/0bps           456bps/680bps       57/85
69 69.192.34.24    0bps/0bps           14.6kbps/9.1kbps    7304/5093
70 66.220.149.25   0bps/0bps           41.6kbps/31.9kbps   11276/8231
71 74.12.240.25    0bps/0bps           0bps/1008bps        0/126
72 71.235.80.26    0bps/0bps           0bps/760bps         0/95
73 74.125.110.26   0bps/0bps           640bps/368bps       160/92
74 201.94.219.26   0bps/0bps           768bps/688bps       202/224
75 74.240.231.26   0bps/0bps           0bps/1072bps        0/134
76 189.252.5.27    0bps/0bps           0bps/792bps         0/99
77 24.137.86.27    0bps/0bps           488bps/0bps         61/0
78 24.192.93.27    0bps/0bps           2.1kbps/3.1kbps     581/791
79 208.43.202.27   0bps/0bps           1648bps/2.2kbps     206/284
80 64.4.44.28      0bps/0bps           640bps/2.0kbps      80/254
81 74.116.94.28    0bps/0bps           0bps/792bps         0/99
82 113.193.76.29   0bps/0bps           0bps/1032bps        0/129
83 208.73.210.29   0bps/0bps           384bps/0bps         144/0
84 24.71.223.29    0bps/0bps           46.7kbps/1644.5kbps 19151/782409
85 72.27.156.30    0bps/0bps           0bps/464bps         0/260
86 83.10.12.31     0bps/0bps           0bps/1072bps        0/134
87 216.82.19.31    0bps/0bps           10.5kbps/38.2kbps   6949/83098
88 93.22.23.31     0bps/0bps           7.7kbps/3.2kbps     5251/6120
89 68.38.55.31     0bps/0bps           1072bps/1072bps     287/278
90 113.190.136.31  0bps/0bps           1472bps/22.8kbps    2460/71740
91 62.87.147.32    0bps/0bps           0bps/416bps         0/152
92 66.220.149.32   0bps/0bps           54.8kbps/46.4kbps   11347/12572
93 124.160.85.33   0bps/0bps           0bps/2.0kbps        0/525
94 193.110.115.33  0bps/0bps           0bps/1048bps        0/131
95 186.2.144.33    0bps/0bps           1072bps/0bps        134/0
96 190.100.189.33  0bps/0bps           1024bps/960bps      977/456
97 85.165.54.34    0bps/0bps           0bps/1048bps        0/131
98 216.82.19.35    0bps/0bps           9.8kbps/30.3kbps    2573/54898
99 218.211.28.35   0bps/0bps           0bps/416bps         0/100
100 70.51.53.35     0bps/0bps           0bps/792bps         0/99
101 178.32.60.35    0bps/0bps           89.0kbps/899.6kbps  83191/1334800
102 208.185.127.35  0bps/0bps           0bps/368bps         0/230
103 142.162.177.35  0bps/0bps           0bps/792bps         0/99
104 198.105.197.35  0bps/0bps           1248bps/1200bps     156/150
105 64.4.34.36      0bps/0bps           680bps/9.4kbps      210/1275
106 66.220.145.36   0bps/0bps           0bps/368bps         0/46
107 198.105.197.37  0bps/0bps           8.2kbps/5.3kbps     1025/666
108 68.63.212.37    0bps/0bps           0bps/1048bps        0/131
109 178.156.173.38  0bps/0bps           1072bps/2.6kbps     134/335
110 196.201.228.38  0bps/0bps           0bps/1032bps        0/129
111 66.40.5.39      0bps/0bps           58.2kbps/746.9kbps  21962/196013
112 65.55.17.39     0bps/0bps           320bps/0bps         40/0
113 208.43.64.39    0bps/0bps           4.4kbps/3.1kbps     602/393
114 65.50.105.39    0bps/0bps           9.2kbps/434.7kbps   5811/224183
115 74.125.110.39   0bps/0bps           15.9kbps/44.9kbps   4592/12743
116 87.97.144.39    0bps/0bps           1456bps/5.0kbps     316/719
117 76.175.217.39   0bps/0bps           0bps/848bps         0/260
118 173.174.89.40   0bps/0bps           1008bps/23.0kbps    951/36738
119 68.186.89.41    0bps/0bps           0bps/760bps         0/95
120 66.119.185.41   0bps/0bps           79.6kbps/601.8kbps  193800/605592
121 65.61.209.41    0bps/0bps           1792bps/2.1kbps     431/489
122 78.169.15.42    0bps/0bps           4.7kbps/7.0kbps     1936/1550
123 117.206.35.42   0bps/0bps           464bps/0bps         164/0
124 66.40.5.43      0bps/0bps           38.0kbps/160.1kbps  5590/21972
125 64.4.44.43      0bps/0bps           680bps/384bps       85/48
126 188.134.19.44   0bps/0bps           0bps/1048bps        0/131
127 122.21.23.44    0bps/0bps           1072bps/2.8kbps     134/353
128 94.3.51.44      0bps/0bps           0bps/760bps         0/95
129 71.191.67.44    0bps/0bps           0bps/384bps         0/192
130 114.185.119.44  0bps/0bps           0bps/1032bps        0/129
131 66.220.147.44   0bps/0bps           0bps/368bps         0/46
132 41.31.191.44    0bps/0bps           0bps/944bps         0/454
133 65.203.229.44   0bps/0bps           9.5kbps/41.3kbps    4545/11442
134 208.43.64.45    0bps/0bps           4.8kbps/3.1kbps     610/393
135 69.63.180.45    0bps/0bps           4.6kbps/2.6kbps     659/377
136 216.82.5.46     0bps/0bps           10.6kbps/10.6kbps   1401/1327
137 97.120.100.46   0bps/0bps           0bps/792bps         0/99
138 70.35.74.47     0bps/0bps           488bps/0bps         61/0
139 124.171.199.47  0bps/0bps           0bps/384bps         0/96
140 142.169.1.48    0bps/0bps           431.6kbps/12.5kbps  1287240/42076
141 24.200.46.48    0bps/0bps           0bps/800bps         0/304
142 60.50.87.48     0bps/0bps           768bps/368bps       144/138
143 216.239.116.48  0bps/0bps           320bps/0bps         40/0
144 63.215.202.48   0bps/0bps           320bps/368bps       80/46
145 142.68.140.49   0bps/0bps           3.9kbps/2.0kbps     1573/1384
146 70.42.62.50     0bps/0bps           28.1kbps/10.9kbps   4387/2857
147 216.239.116.50  0bps/0bps           640bps/0bps         80/0
148 189.73.146.50   0bps/0bps           0bps/760bps         0/95
149 41.248.173.50   0bps/0bps           464bps/0bps         116/0
150 75.134.178.50   0bps/0bps           0bps/800bps         0/304
151 77.96.48.51     0bps/0bps           0bps/464bps         0/58
152 93.150.17.52    0bps/0bps           0bps/872bps         0/388
153 90.220.30.52    0bps/0bps           8.4kbps/560bps      1182/70
154 94.68.44.52     0bps/0bps           0bps/848bps         0/260
155 68.184.55.52    0bps/0bps           960bps/2.2kbps      985/3246
156 78.154.130.52   0bps/0bps           2.1kbps/11.4kbps    565/5182
157 70.68.161.52    0bps/0bps           1056bps/416bps      1052/572
158 68.57.209.52    0bps/0bps           2.8kbps/3.3kbps     2373/5434
159 188.134.6.53    0bps/0bps           0bps/1072bps        0/134
160 98.127.113.53   0bps/0bps           0bps/1048bps        0/131
161 65.34.151.53    0bps/0bps           1808bps/2.2kbps     2009/3432
162 207.246.193.53  0bps/0bps           10.1kbps/2.2kbps    5627/700
163 24.147.44.54    0bps/0bps           0bps/744bps         0/93
164 99.243.63.54    0bps/0bps           1832bps/4.6kbps     1942/6102
165 10.25.200.54    0bps/0bps           0bps/320bps         0/200
166 94.168.248.54   0bps/0bps           0bps/1048bps        0/131
167 74.198.148.55   0bps/0bps           896bps/896bps       249/404
168 10.25.200.56    0bps/0bps           0bps/640bps         0/320
169 67.185.229.56   0bps/0bps           384bps/368bps       144/138
170 190.12.68.57    0bps/0bps           1072bps/0bps        134/0
171 95.52.80.57     0bps/0bps           0bps/1072bps        0/134
172 69.89.31.58     0bps/0bps           416bps/0bps         156/0
173 60.228.66.58    0bps/0bps           0bps/792bps         0/169
174 66.235.138.59   0bps/0bps           11.9kbps/6.5kbps    1493/870
175 124.13.157.59   0bps/0bps           464bps/0bps         116/0
176 216.82.20.61    0bps/0bps           5.4kbps/37.2kbps    2861/54062
177 69.120.40.61    0bps/0bps           0bps/1048bps        0/131
178 66.38.122.61    0bps/0bps           0bps/384bps         0/240
179 59.180.145.61   0bps/0bps           0bps/464bps         0/116
180 71.57.156.61    0bps/0bps           2.2kbps/3.5kbps     3377/9221
181 86.15.187.62    0bps/0bps           1504bps/784bps      384/192
182 208.71.42.63    0bps/0bps           320bps/368bps       80/92
183 142.177.210.63  0bps/0bps           1072bps/0bps        134/0
184 219.78.21.64    0bps/0bps           0bps/1008bps        0/126
185 188.134.33.64   0bps/0bps           0bps/1048bps        0/131
186 65.54.95.64     0bps/0bps           10.7kbps/23.8kbps   1461/4252
187 64.94.126.65    0bps/0bps           1728bps/896bps      216/112
188 68.127.157.65   0bps/0bps           0bps/632bps         0/79
189 98.245.218.66   0bps/0bps           7.4kbps/7.6kbps     1718/2943
190 216.52.233.67   0bps/0bps           992bps/368bps       124/46
191 208.96.4.68     0bps/0bps           320bps/368bps       80/46
192 151.95.16.68    0bps/0bps           137.2kbps/3.9kbps   292008/8914
193 65.54.95.68     0bps/0bps           8.2kbps/58.7kbps    2140/11672
194 114.37.7.69     0bps/0bps           0bps/1008bps        0/126
195 174.31.209.69   0bps/0bps           0bps/744bps         0/93
196 190.105.44.70   0bps/0bps           0bps/1048bps        0/131
197 208.50.77.70    0bps/0bps           12.9kbps/12.0kbps   4776/2675
198 66.220.151.70   0bps/0bps           9.2kbps/1896bps     1158/237
199 194.146.155.70  0bps/0bps           848bps/0bps         260/0
200 173.174.85.71   0bps/0bps           0bps/416bps         0/204
201 95.234.191.71   0bps/0bps           229.1kbps/8.0kbps   662570/21292
202 208.50.77.72    0bps/0bps           12.6kbps/8.4kbps    8771/3257
203 66.220.151.72   0bps/0bps           10.1kbps/1528bps    1269/237
204 76.27.173.72    0bps/0bps           488bps/0bps         61/0
205 208.50.77.73    0bps/0bps           13.3kbps/3.5kbps    1715/486
206 66.220.151.73   0bps/0bps           9.0kbps/1848bps     1170/277
207 96.254.33.74    0bps/0bps           456bps/920bps       57/115
208 76.171.95.74    0bps/0bps           0bps/464bps         0/116
209 76.102.108.74   0bps/0bps           0bps/792bps         0/99
210 66.220.151.74   0bps/0bps           12.4kbps/2.2kbps    1557/283
211 109.110.93.75   0bps/0bps           1072bps/0bps        134/0
212 74.127.219.75   0bps/0bps           0bps/368bps         0/46
213 121.84.239.75   0bps/0bps           672bps/760bps       124/187
214 80.6.253.75     0bps/0bps           1072bps/3.0kbps     134/385
215 68.83.17.77     0bps/0bps           0bps/792bps         0/99
216 82.61.79.77     0bps/0bps           0bps/384bps         0/96
217 86.30.149.77    0bps/0bps           0bps/760bps         0/95
218 74.101.211.77   0bps/0bps           1072bps/1336bps     488/582
219 64.4.34.78      0bps/0bps           20.5kbps/2.3kbps    2572/344
220 64.4.44.78      0bps/0bps           320bps/368bps       40/46
221 173.206.79.78   0bps/0bps           384bps/0bps         48/0
222 173.74.195.78   0bps/0bps           6.8kbps/3.1kbps     950/587
223 108.16.2.79     0bps/0bps           1072bps/1048bps     394/579
224 89.212.139.79   0bps/0bps           1072bps/768bps      239/240
225 74.114.8.80     0bps/0bps           20.2kbps/117.2kbps  9108/29008
226 86.14.78.80     0bps/0bps           0bps/880bps         0/268
227 68.57.104.80    0bps/0bps           976bps/560bps       122/70
228 66.220.151.80   0bps/0bps           9.6kbps/1896bps     1212/237
229 125.192.222.80  0bps/0bps           0bps/1008bps        0/126
230 208.50.77.81    0bps/0bps           9.8kbps/10.0kbps    3891/2991
231 201.220.233.81  0bps/0bps           464bps/464bps       116/228
232 66.220.151.82   0bps/0bps           9.1kbps/1896bps     1148/237
233 180.188.231.82  0bps/0bps           5.4kbps/5.3kbps     2293/2190
234 98.166.22.83    0bps/0bps           0bps/416bps         0/52
235 74.125.53.83    0bps/0bps           1496bps/2.3kbps     307/567
236 74.125.127.83   0bps/0bps           65.5kbps/15.0kbps   24056/9001
237 66.220.151.83   0bps/0bps           40.4kbps/5.8kbps    12323/2949
238 72.240.206.83   0bps/0bps           1280bps/640bps      390/242
239 17.250.248.83   0bps/0bps           2.0kbps/368bps      410/92
240 69.114.239.84   0bps/0bps           560bps/584bps       700/730
241 120.140.245.84  0bps/0bps           0bps/1048bps        0/131
242 190.58.193.85   0bps/0bps           0bps/464bps         0/116
243 76.179.203.85   0bps/0bps           0bps/768bps         0/288
244 67.49.221.85    0bps/0bps           1480bps/2.1kbps     1234/3444
245 67.202.94.86    0bps/0bps           5.1kbps/5.1kbps     641/648
246 203.192.208.86  0bps/0bps           0bps/1072bps        0/134
247 60.48.228.86    0bps/0bps           0bps/848bps         0/260
248 74.211.45.87    0bps/0bps           0bps/792bps         0/169
249 70.70.49.87     0bps/0bps           1240bps/480bps      155/60
250 87.198.59.87    0bps/0bps           0bps/760bps         0/95
251 208.50.77.87    0bps/0bps           21.6kbps/107.0kbps  4087/19571
252 207.46.124.87   0bps/0bps           4.0kbps/2.0kbps     2002/770
253 220.245.254.87  0bps/0bps           1072bps/0bps        134/0
254 41.71.136.88    0bps/0bps           0bps/792bps         0/169
255 10.25.200.88    0bps/0bps           0bps/320bps         0/40
256 69.99.255.88    0bps/0bps           0bps/792bps         0/169
257 68.197.51.89    0bps/0bps           0bps/928bps         0/756
258 208.50.77.89    0bps/0bps           32.1kbps/130.9kbps  10206/37634
259 204.187.87.89   0bps/0bps           2.3kbps/656bps      299/82
260 99.170.98.89    0bps/0bps           1280bps/2.7kbps     552/881
261 10.25.200.89    0bps/0bps           0bps/416bps         0/52
262 204.213.228.89  0bps/0bps           1064bps/3.0kbps     1373/3817
263 216.9.242.89    0bps/0bps           576bps/576bps       112/72
264 184.87.61.90    0bps/0bps           63.0kbps/141.9kbps  29234/48223
265 65.54.95.90     0bps/0bps           7.0kbps/1648bps     998/346
266 98.166.194.90   0bps/0bps           0bps/848bps         0/260
267 79.33.235.90    0bps/0bps           1416bps/464bps      556/58
268 188.223.37.91   0bps/0bps           0bps/880bps         0/110
269 64.4.61.91      0bps/0bps           320bps/368bps       40/46
270 199.212.20.92   0bps/0bps           5.0kbps/4.4kbps     1530/1330
271 122.16.143.92   0bps/0bps           0bps/1032bps        0/129
272 74.125.127.93   0bps/0bps           43.7kbps/504.3kbps  8418/89047
273 212.58.246.93   0bps/0bps           320bps/368bps       80/92
274 93.48.65.94     0bps/0bps           464bps/0bps         202/0
275 208.50.77.94    0bps/0bps           27.7kbps/324.5kbps  11320/102548
276 72.27.88.94     0bps/0bps           0bps/464bps         0/116
277 78.29.167.94    0bps/0bps           1280bps/2.1kbps     648/1052
278 216.239.113.95  0bps/0bps           320bps/0bps         40/0
279 211.40.122.95   0bps/0bps           2.1kbps/768bps      325/144
280 74.125.127.95   0bps/0bps           10.8kbps/17.7kbps   1394/4365
281 201.89.148.95   0bps/0bps           34.3kbps/1304bps    46687/1200
282 142.68.239.95   0bps/0bps           0bps/464bps         0/116
283 208.50.77.96    0bps/0bps           320bps/0bps         40/0
284 24.11.128.96    0bps/0bps           0bps/744bps         0/93
285 71.215.136.96   0bps/0bps           5.4kbps/2.7kbps     2966/6433
286 217.172.29.97   0bps/0bps           0bps/1048bps        0/131
287 74.125.127.97   0bps/0bps           18.2kbps/9.6kbps    2323/1201
288 72.14.213.97    0bps/0bps           31.0kbps/39.7kbps   10443/16039
289 128.241.220.97  0bps/0bps           92.8kbps/413.6kbps  14031/77777
290 98.246.67.98    0bps/0bps           2.1kbps/2.7kbps     581/673
291 74.192.75.98    0bps/0bps           4.6kbps/560bps      585/70
292 209.205.94.98   0bps/0bps           6.0Mbps/1537.3kbps  15945574/6673253
293 209.205.94.99   0bps/0bps           2.0kbps/20.4kbps    6733/24012
294 74.125.127.99   0bps/0bps           23.5kbps/381.5kbps  6513/96689
295 192.168.1.100   0bps/0bps           0bps/1248bps        0/231
296 74.125.45.100   0bps/0bps           8.2kbps/6.8kbps     4442/3578
297 24.8.92.100     0bps/0bps           0bps/416bps         0/152
298 74.125.127.100  0bps/0bps           7.8kbps/3.0kbps     2002/806
299 217.118.135.100 0bps/0bps           5.2kbps/23.2kbps    813/3005
300 217.118.66.101  0bps/0bps           0bps/1048bps        0/131
301 209.205.94.101  0bps/0bps           1646.0kbps/48.0kbps 786322/22179
302 74.125.127.101  0bps/0bps           640bps/368bps       240/46
303 74.125.155.101  0bps/0bps           320bps/0bps         120/0
304 72.14.213.101   0bps/0bps           12.1kbps/15.2kbps   1516/1904
305 85.115.21.102   0bps/0bps           416bps/0bps         52/0
306 74.125.53.102   0bps/0bps           640bps/0bps         80/0
307 209.205.94.102  0bps/0bps           4.4kbps/5.0kbps     1330/1530
308 74.125.127.102  0bps/0bps           640bps/0bps         120/0
309 66.203.195.102  0bps/0bps           0bps/760bps         0/95
310 65.55.85.103    0bps/0bps           0bps/368bps         0/46
311 209.205.94.103  0bps/0bps           600bps/952bps       525/1666
312 190.204.211.103 0bps/0bps           0bps/848bps         0/260
313 209.205.94.104  0bps/0bps           647.9kbps/120.3kbps 881919/224927
314 122.122.130.104 0bps/0bps           0bps/1032bps        0/129
315 198.107.131.104 0bps/0bps           648bps/880bps       133/162
316 182.173.200.104 0bps/0bps           0bps/464bps         0/116
317 72.14.213.104   0bps/0bps           320bps/0bps         40/0
318 128.241.220.104 0bps/0bps           640bps/368bps       80/46
319 69.127.121.105  0bps/0bps           976bps/0bps         122/0
320 74.125.127.105  0bps/0bps           30.6kbps/66.2kbps   9502/19999
321 74.125.127.106  0bps/0bps           640bps/368bps       80/46
322 72.229.96.107   0bps/0bps           0bps/384bps         0/48
323 70.40.147.107   0bps/0bps           0bps/760bps         0/95
324 93.71.133.108   0bps/0bps           0bps/1048bps        0/131
325 75.85.159.108   0bps/0bps           0bps/384bps         0/48
326 216.82.28.109   0bps/0bps           41.0kbps/367.5kbps  94284/881767
327 173.3.22.110    0bps/0bps           0bps/792bps         0/99
328 203.59.25.110   0bps/0bps           1072bps/0bps        134/0
329 208.50.77.110   0bps/0bps           13.4kbps/48.5kbps   2423/9199
330 68.11.210.110   0bps/0bps           2.3kbps/2.7kbps     2442/3971
331 67.183.254.110  0bps/0bps           0bps/792bps         0/99
332 213.89.83.111   0bps/0bps           464bps/0bps         260/0
333 79.36.130.111   0bps/0bps           1072bps/2.9kbps     134/369
334 193.27.216.111  0bps/0bps           384bps/0bps         48/0
335 24.49.42.112    0bps/0bps           0bps/848bps         0/376
336 208.50.77.112   0bps/0bps           320bps/0bps         40/0
337 79.227.231.112  0bps/0bps           0bps/384bps         0/144
338 94.192.245.112  0bps/0bps           0bps/1048bps        0/131
339 74.125.127.113  0bps/0bps           20.4kbps/12.7kbps   14365/8493
340 74.125.155.113  0bps/0bps           7.0kbps/8.8kbps     959/1468
341 68.34.16.114    0bps/0bps           0bps/464bps         0/116
342 82.231.39.114   0bps/0bps           0bps/384bps         0/240
343 117.194.1.115   0bps/0bps           46.4kbps/59.1kbps   104433/72097
344 113.131.10.115  0bps/0bps           125.8kbps/5.4kbps   198196/7521
345 69.60.4.116     0bps/0bps           456bps/0bps         171/0
346 209.151.10.116  0bps/0bps           480bps/0bps         840/0
347 125.1.114.116   0bps/0bps           0bps/1032bps        0/129
348 184.72.45.117   0bps/0bps           832bps/832bps       156/208
349 89.100.159.117  0bps/0bps           0bps/744bps         0/93
350 204.201.160.117 0bps/0bps           56.4kbps/2.3Mbps    107694/4124976
351 74.125.127.118  0bps/0bps           3.8kbps/0bps        1240/0
352 114.79.135.118  0bps/0bps           1312bps/464bps      750/154
353 97.106.152.118  0bps/0bps           456bps/920bps       57/115
354 65.55.158.118   0bps/0bps           2.8kbps/2.8kbps     1562/2432
355 67.70.201.118   0bps/0bps           0bps/384bps         0/48
356 98.212.12.119   0bps/0bps           0bps/792bps         0/169
357 128.241.220.119 0bps/0bps           0bps/11.5kbps       0/1441
358 64.4.61.120     0bps/0bps           680bps/384bps       189/144
359 192.168.123.120 0bps/0bps           848bps/0bps         424/0
360 83.119.171.120  0bps/0bps           0bps/464bps         0/58
361 98.148.210.120  0bps/0bps           0bps/384bps         0/288
362 208.50.77.121   0bps/0bps           320bps/0bps         40/0
363 66.235.139.121  0bps/0bps           55.5kbps/12.6kbps   19054/6898
364 64.4.34.122     0bps/0bps           680bps/384bps       85/48
365 64.4.62.123     0bps/0bps           320bps/0bps         40/0
366 84.83.12.124    0bps/0bps           0bps/464bps         0/168
367 95.135.94.124   0bps/0bps           0bps/1048bps        0/131
368 92.96.125.124   0bps/0bps           0bps/384bps         0/144
369 117.204.161.124 0bps/0bps           848bps/0bps         260/0
370 10.25.200.124   0bps/0bps           0bps/320bps         0/80
371 64.4.61.125     0bps/0bps           360bps/384bps       85/48
372 75.158.11.126   0bps/0bps           488bps/0bps         61/0
373 75.64.41.126    0bps/0bps           47.3kbps/2.5kbps    149180/5539
374 66.110.141.126  0bps/0bps           0bps/416bps         0/152
375 60.240.142.126  0bps/0bps           0bps/1048bps        0/131
376 216.18.232.126  0bps/0bps           1072bps/1520bps     688/1018
377 8.20.73.127     0bps/0bps           320bps/0bps         40/0
378 208.50.77.127   0bps/0bps           320bps/0bps         40/0
379 76.99.57.128    0bps/0bps           0bps/384bps         0/48
380 99.245.126.128  0bps/0bps           0bps/760bps         0/95
381 193.6.52.129    0bps/0bps           0bps/1048bps        0/131
382 208.50.77.129   0bps/0bps           416bps/0bps         52/0
383 78.149.124.129  0bps/0bps           0bps/1048bps        0/131
384 67.215.65.130   0bps/0bps           15.1kbps/6.8kbps    3167/5050
385 206.12.182.130  0bps/0bps           472bps/0bps         413/0
386 38.106.205.131  0bps/0bps           13.4kbps/6.3kbps    7612/3231
387 67.215.65.132   0bps/0bps           0bps/368bps         0/46
388 174.58.86.132   0bps/0bps           0bps/384bps         0/192
389 64.231.100.132  0bps/0bps           0bps/760bps         0/95
390 74.125.127.132  0bps/0bps           832bps/416bps       224/52
391 63.251.254.132  0bps/0bps           320bps/0bps         40/0
392 70.232.80.133   0bps/0bps           1072bps/1016bps     239/271
393 68.142.93.133   0bps/0bps           102.0kbps/1441.0... 57356/804293
394 121.54.17.134   0bps/0bps           0bps/384bps         0/144
395 88.173.19.134   0bps/0bps           488bps/0bps         122/0
396 79.154.50.134   0bps/0bps           194.4kbps/3.8kbps   376474/9017
397 93.139.61.134   0bps/0bps           0bps/464bps         0/116
398 74.201.99.134   0bps/0bps           36.4kbps/5.1kbps    15224/3822
399 64.34.211.134   0bps/0bps           320bps/368bps       40/46
400 166.137.10.135  0bps/0bps           0bps/976bps         0/468
401 77.67.109.135   0bps/0bps           1696bps/57.6kbps    5548/224746
402 94.96.165.135   0bps/0bps           137.2kbps/4.3kbps   300540/9135
403 208.67.216.135  0bps/0bps           14.9kbps/18.2kbps   3284/6539
404 208.50.77.136   0bps/0bps           37.8kbps/358.2kbps  12468/56173
405 74.125.127.136  0bps/0bps           640bps/0bps         80/0
406 38.106.205.136  0bps/0bps           14.6kbps/691.6kbps  14944/663304
407 187.113.1.137   0bps/0bps           0bps/1048bps        0/131
408 213.204.117.137 0bps/0bps           848bps/0bps         434/0
409 67.191.206.137  0bps/0bps           0bps/464bps         0/58
410 117.200.229.137 0bps/0bps           464bps/0bps         260/0
411 72.226.93.138   0bps/0bps           0bps/384bps         0/48
412 24.65.117.138   0bps/0bps           3.7kbps/2.3kbps     2443/3733
413 74.125.127.138  0bps/0bps           17.2kbps/7.7kbps    7210/4068
414 68.195.138.138  0bps/0bps           0bps/384bps         0/48
415 72.14.213.138   0bps/0bps           960bps/0bps         120/0
416 80.174.53.139   0bps/0bps           384bps/0bps         48/0
417 83.57.67.139    0bps/0bps           768bps/448bps       260/250
418 96.25.25.141    0bps/0bps           1192bps/2.8kbps     1373/4016
419 208.50.77.142   0bps/0bps           320bps/0bps         40/0
420 188.49.19.143   0bps/0bps           114.7kbps/36.0kbps  138623/66256
421 216.220.46.143  0bps/0bps           97.1kbps/237.5kbps  55010/166389
422 69.125.254.144  0bps/0bps           2.1kbps/384bps      325/144
423 94.41.24.146    0bps/0bps           1072bps/0bps        134/0
424 173.223.232.146 0bps/0bps           35.3kbps/1268.0kbps 28707/1030509
425 70.80.44.147    0bps/0bps           4.5kbps/1120bps     571/140
426 99.179.148.147  0bps/0bps           0bps/760bps         0/95
427 99.226.206.147  0bps/0bps           0bps/464bps         0/260
428 72.14.213.147   0bps/0bps           19.9kbps/125.6kbps  2539/16003
429 24.207.6.148    0bps/0bps           22.1kbps/2.4kbps    3239/354
430 65.54.95.148    0bps/0bps           3.0kbps/3.8kbps     467/526
431 74.125.127.148  0bps/0bps           10.4kbps/22.7kbps   1573/2892
432 114.186.124.149 0bps/0bps           0bps/1048bps        0/131
433 74.125.127.149  0bps/0bps           14.7kbps/128.7kbps  2750/17050
434 79.147.141.149  0bps/0bps           0bps/760bps         0/95
435 96.245.14.150   0bps/0bps           488bps/0bps         61/0
436 74.125.164.150  0bps/0bps           27.6kbps/58.2kbps   4629/7332
437 80.77.156.151   0bps/0bps           1072bps/1296bps     134/162
438 72.93.175.151   0bps/0bps           0bps/384bps         0/48
439 70.71.228.151   0bps/0bps           488bps/0bps         61/0
440 72.27.28.152    0bps/0bps           0bps/848bps         0/154
441 70.42.62.152    0bps/0bps           600bps/0bps         75/0
442 128.241.90.152  0bps/0bps           640bps/368bps       320/46
443 94.132.94.152   0bps/0bps           0bps/760bps         0/95
444 84.241.17.153   0bps/0bps           1224bps/2.2kbps     460/536
445 98.82.85.153    0bps/0bps           464bps/928bps       106/338
446 128.241.90.153  0bps/0bps           640bps/736bps       80/92
447 75.66.89.154    0bps/0bps           0bps/464bps         0/260
448 109.255.147.154 0bps/0bps           2.5kbps/11.8kbps    1754/36920
449 173.28.161.154  0bps/0bps           1696bps/69.1kbps    3084/134113
450 10.25.200.154   0bps/0bps           0bps/320bps         0/40
451 74.125.127.155  0bps/0bps           12.4kbps/53.3kbps   2121/7411
452 65.55.184.155   0bps/0bps           302.9kbps/39.2kbps  113046/10773
453 173.223.232.155 0bps/0bps           4.5kbps/36.6kbps    976/4628
454 122.179.32.156  0bps/0bps           0bps/464bps         0/58
455 124.40.51.156   0bps/0bps           488bps/752bps       61/94
456 74.125.110.156  0bps/0bps           17.8kbps/760.8kbps  44084/1848962
457 74.125.127.156  0bps/0bps           20.0kbps/422.4kbps  7812/58905
458 64.4.55.157     0bps/0bps           14.6kbps/45.8kbps   1831/5776
459 92.7.105.157    0bps/0bps           0bps/792bps         0/99
460 85.146.84.158   0bps/0bps           0bps/384bps         0/48
461 65.54.95.158    0bps/0bps           8.9kbps/58.8kbps    1203/7403
462 201.14.132.158  0bps/0bps           0bps/1048bps        0/131
463 69.25.138.158   0bps/0bps           832bps/0bps         104/0
464 74.180.10.159   0bps/0bps           0bps/984bps         0/123
465 10.25.200.159   0bps/0bps           0bps/2.5kbps        0/1080
466 209.107.220.159 0bps/0bps           488bps/0bps         61/0
467 71.177.142.160  0bps/0bps           0bps/848bps         0/260
468 98.242.201.160  0bps/0bps           0bps/848bps         0/260
469 67.134.208.160  0bps/0bps           4.5kbps/3.1kbps     565/388
470 90.200.186.161  0bps/0bps           0bps/1072bps        0/134
471 111.93.212.161  0bps/0bps           0bps/464bps         0/116
472 174.129.248.161 0bps/0bps           19.8kbps/6.0kbps    2526/807
473 142.162.26.162  0bps/0bps           0bps/848bps         0/260
474 65.8.146.162    0bps/0bps           464bps/0bps         202/0
475 201.137.34.163  0bps/0bps           1072bps/2.8kbps     134/350
476 173.18.38.163   0bps/0bps           4.7kbps/6.2kbps     1485/1072
477 64.4.61.163     0bps/0bps           8.7kbps/11.6kbps    1176/1500
478 84.52.73.163    0bps/0bps           0bps/1048bps        0/131
479 123.100.109.163 0bps/0bps           0bps/1048bps        0/131
480 62.10.152.163   0bps/0bps           0bps/1048bps        0/131
481 64.4.61.164     0bps/0bps           680bps/384bps       85/48
482 76.64.34.165    0bps/0bps           0bps/792bps         0/99
483 70.78.54.166    0bps/0bps           20.4kbps/2.0kbps    24012/6733
484 67.193.164.166  0bps/0bps           488bps/0bps         61/0
485 63.193.183.166  0bps/0bps           1072bps/2.8kbps     134/353
486 74.125.127.167  0bps/0bps           19.9kbps/219.9kbps  6370/54647
487 98.226.149.167  0bps/0bps           0bps/1048bps        0/131
488 65.246.112.168  0bps/0bps           0bps/1048bps        0/131
489 24.65.91.169    0bps/0bps           488bps/0bps         61/0
490 93.184.216.169  0bps/0bps           142.7kbps/173.0kbps 66664/87671
491 76.74.140.170   0bps/0bps           12.7kbps/896bps     1598/112
492 64.88.164.170   0bps/0bps           34.5kbps/9.7kbps    9267/3329
493 74.83.220.170   0bps/0bps           0bps/792bps         0/99
494 216.239.113.172 0bps/0bps           320bps/0bps         40/0
495 74.235.0.173    0bps/0bps           0bps/464bps         0/58
496 88.181.5.173    0bps/0bps           1072bps/1128bps     335/337
497 83.251.212.173  0bps/0bps           0bps/464bps         0/260
498 72.51.60.174    0bps/0bps           23.9kbps/75.2kbps   119064/231445
499 98.188.118.174  0bps/0bps           0bps/792bps         0/99
500 71.227.42.175   0bps/0bps           0bps/464bps         0/232
501 111.93.212.175  0bps/0bps           464bps/0bps         260/0
502 98.225.14.176   0bps/0bps           0bps/800bps         0/252
503 128.241.90.176  0bps/0bps           1600bps/1104bps     440/276
504 173.202.94.176  0bps/0bps           1456bps/11.8kbps    962/20269
505 98.213.129.176  0bps/0bps           0bps/464bps         0/116
506 216.137.35.178  0bps/0bps           0bps/416bps         0/52
507 68.142.116.178  0bps/0bps           896bps/512bps       560/64
508 94.167.149.178  0bps/0bps           36.9kbps/48.6kbps   124295/88100
509 82.37.195.178   0bps/0bps           0bps/880bps         0/220
510 140.174.24.179  0bps/0bps           11.3kbps/47.1kbps   1424/5891
511 128.241.90.179  0bps/0bps           1920bps/1104bps     920/138
512 68.142.116.179  0bps/0bps           1408bps/2.5kbps     1296/2496
513 65.55.42.180    0bps/0bps           480bps/1152bps      240/288
514 60.49.63.180    0bps/0bps           0bps/464bps         0/164
515 70.32.81.180    0bps/0bps           51.3kbps/524.7kbps  26723/243176
516 71.20.104.180   0bps/0bps           0bps/464bps         0/116
517 24.117.147.181  0bps/0bps           0bps/384bps         0/240
518 87.228.238.181  0bps/0bps           0bps/416bps         0/152
519 173.67.5.183    0bps/0bps           0bps/760bps         0/95
520 84.48.41.183    0bps/0bps           0bps/848bps         0/376
521 98.14.113.183   0bps/0bps           0bps/880bps         0/268
522 75.138.122.183  0bps/0bps           0bps/792bps         0/99
523 72.39.141.183   0bps/0bps           0bps/464bps         0/58
524 125.56.208.183  0bps/0bps           496bps/752bps       62/94
525 174.117.212.183 0bps/0bps           0bps/880bps         0/268
526 72.51.84.184    0bps/0bps           0bps/760bps         0/95
527 190.179.155.184 0bps/0bps           1072bps/3.6kbps     134/457
528 81.225.142.185  0bps/0bps           229.1kbps/5.4kbps   618624/16692
529 10.25.200.185   0bps/0bps           0bps/320bps         0/40
530 111.93.212.185  0bps/0bps           464bps/0bps         260/0
531 216.52.233.185  0bps/0bps           936bps/616bps       468/308
532 71.87.247.185   0bps/0bps           2.1kbps/768bps      325/144
533 82.52.147.186   0bps/0bps           69.0kbps/2.4kbps    140524/4043
534 76.68.22.187    0bps/0bps           0bps/464bps         0/58
535 24.209.204.187  0bps/0bps           0bps/792bps         0/99
536 68.192.236.187  0bps/0bps           1072bps/1024bps     383/376
537 74.200.247.187  0bps/0bps           8.5kbps/12.2kbps    1072/1589
538 71.236.98.188   0bps/0bps           1328bps/1128bps     255/279
539 24.131.96.189   0bps/0bps           3.0kbps/7.7kbps     2290/3990
540 74.125.127.189  0bps/0bps           736bps/4.8kbps      172/902
541 180.131.228.189 0bps/0bps           1200bps/31.6kbps    1464/16308
542 216.52.233.189  0bps/0bps           616bps/616bps       234/154
543 64.121.16.191   0bps/0bps           0bps/1048bps        0/131
544 125.56.208.191  0bps/0bps           600bps/744bps       75/93
545 14.202.32.192   0bps/0bps           464bps/0bps         260/0
546 92.245.175.193  0bps/0bps           768bps/752bps       240/480
547 89.210.248.194  0bps/0bps           0bps/792bps         0/99
548 94.182.150.196  0bps/0bps           1112bps/6.0kbps     811/4215
549 201.86.134.197  0bps/0bps           464bps/368bps       260/138
550 210.6.172.197   0bps/0bps           0bps/1008bps        0/126
551 72.82.187.197   0bps/0bps           0bps/560bps         0/70
552 98.226.98.200   0bps/0bps           0bps/792bps         0/99
553 204.194.232.200 0bps/0bps           808bps/1128bps      289/333
554 173.35.253.201  0bps/0bps           0bps/1048bps        0/131
555 196.213.31.203  0bps/0bps           0bps/848bps         0/260
556 174.129.40.203  0bps/0bps           320bps/368bps       40/46
557 198.166.224.203 0bps/0bps           0bps/384bps         0/144
558 94.193.71.204   0bps/0bps           0bps/464bps         0/116
559 209.170.122.204 0bps/0bps           456bps/0bps         171/0
560 96.6.205.205    0bps/0bps           0bps/712bps         0/178
561 70.29.64.206    0bps/0bps           0bps/464bps         0/116
562 24.186.222.207  0bps/0bps           0bps/1048bps        0/131
563 64.46.38.208    0bps/0bps           9.4kbps/7.5kbps     2375/2826
564 128.241.90.208  0bps/0bps           640bps/736bps       160/92
565 221.124.102.208 0bps/0bps           0bps/1008bps        0/126
566 24.164.191.208  0bps/0bps           0bps/416bps         0/256
567 94.155.73.209   0bps/0bps           1072bps/1248bps     287/352
568 216.197.176.209 0bps/0bps           0bps/760bps         0/95
569 74.53.25.210    0bps/0bps           3.4kbps/7.1kbps     587/989
570 128.241.90.210  0bps/0bps           640bps/736bps       80/92
571 74.96.202.210   0bps/0bps           35.8kbps/1848bps    39146/1664
572 216.223.0.211   0bps/0bps           44.9kbps/30.1kbps   5889/3811
573 109.225.103.211 0bps/0bps           0bps/848bps         0/260
574 173.97.222.211  0bps/0bps           1280bps/2.0kbps     489/862
575 220.253.252.211 0bps/0bps           0bps/792bps         0/192
576 174.126.130.212 0bps/0bps           1064bps/2.6kbps     2409/4667
577 67.161.144.212  0bps/0bps           1384bps/3.0kbps     1745/4709
578 86.134.242.212  0bps/0bps           0bps/760bps         0/95
579 70.173.25.213   0bps/0bps           0bps/760bps         0/95
580 80.185.201.213  0bps/0bps           1456bps/4.8kbps     316/695
581 83.248.228.213  0bps/0bps           1472bps/384bps      241/96
582 216.52.233.213  0bps/0bps           936bps/616bps       234/154
583 85.247.73.214   0bps/0bps           0bps/1048bps        0/131
584 87.72.117.214   0bps/0bps           67.3kbps/183.0kbps  232950/599920
585 10.25.200.216   0bps/0bps           0bps/864bps         0/468
586 75.131.125.217  0bps/0bps           0bps/792bps         0/99
587 216.52.233.217  0bps/0bps           936bps/616bps       117/77
588 189.25.106.218  0bps/0bps           464bps/856bps       156/214
589 188.249.176.218 0bps/0bps           0bps/1032bps        0/129
590 41.133.45.219   0bps/0bps           2.5kbps/3.8kbps     1628/10804
591 70.49.92.220    0bps/0bps           1840bps/2.8kbps     460/614
592 208.67.220.220  0bps/0bps           1072bps/2.2kbps     401/882
593 24.176.81.222   0bps/0bps           0bps/792bps         0/99
594 108.69.140.222  0bps/0bps           0bps/880bps         0/314
595 60.53.148.222   0bps/0bps           1072bps/1296bps     134/162
596 208.67.222.222  0bps/0bps           4.0kbps/4.0kbps     1670/2794
597 216.82.22.223   0bps/0bps           320bps/368bps       760/920
598 71.92.41.223    0bps/0bps           0bps/1048bps        0/131
599 68.42.114.223   0bps/0bps           0bps/464bps         0/116
600 76.215.144.223  0bps/0bps           0bps/760bps         0/95
601 216.82.1.225    0bps/0bps           8.1kbps/41.4kbps    3598/53017
602 81.84.93.225    0bps/0bps           162.7kbps/127.3kbps 459668/406351
603 213.248.117.225 0bps/0bps           592bps/0bps         74/0
604 216.52.233.225  0bps/0bps           936bps/616bps       311/154
605 99.62.30.226    0bps/0bps           384bps/0bps         48/0
606 184.59.207.226  0bps/0bps           976bps/0bps         122/0
607 207.219.72.227  0bps/0bps           89.7kbps/180.5kbps  24407/50892
608 77.29.129.227   0bps/0bps           0bps/384bps         0/144
609 174.112.246.227 0bps/0bps           0bps/512bps         0/720
610 24.182.20.228   0bps/0bps           0bps/760bps         0/95
611 207.6.68.228    0bps/0bps           384bps/384bps       96/96
612 95.35.247.228   0bps/0bps           432bps/432bps       106/106
613 207.171.181.229 0bps/0bps           4.9kbps/90.8kbps    613/11360
614 216.52.233.229  0bps/0bps           936bps/616bps       117/77
615 77.166.47.230   0bps/0bps           0bps/1048bps        0/131
616 24.200.139.230  0bps/0bps           7.0kbps/2.7kbps     2598/3808
617 65.55.5.232     0bps/0bps           0bps/736bps         0/92
618 99.119.78.232   0bps/0bps           1072bps/2.6kbps     134/326
619 74.201.99.232   0bps/0bps           0bps/928bps         0/116
620 117.204.160.232 0bps/0bps           1504bps/384bps      440/140
621 75.74.207.232   0bps/0bps           5.3kbps/560bps      669/70
622 65.55.5.233     0bps/0bps           320bps/368bps       80/46
623 108.18.143.233  0bps/0bps           1072bps/1680bps     335/406
624 24.8.160.233    0bps/0bps           1456bps/11.8kbps    1024/18379
625 216.52.233.233  0bps/0bps           936bps/616bps       234/154
626 70.190.64.234   0bps/0bps           6.4kbps/4.8kbps     2395/2378
627 79.181.122.234  0bps/0bps           0bps/760bps         0/95
628 98.160.100.235  0bps/0bps           1064bps/2.4kbps     1757/3319
629 74.56.59.236    0bps/0bps           0bps/384bps         0/240
630 204.93.141.236  0bps/0bps           2.2kbps/60.5kbps    9997/267385
631 208.43.42.237   0bps/0bps           40.3kbps/108.3kbps  13144/29677
632 216.52.233.237  0bps/0bps           936bps/1032bps      311/283
633 180.191.14.238  0bps/0bps           0bps/512bps         0/496
634 174.54.178.238  0bps/0bps           560bps/584bps       560/584
635 76.214.164.239  0bps/0bps           1072bps/1240bps     287/299
636 145.250.56.240  0bps/0bps           976bps/0bps         183/0
637 216.218.86.240  0bps/0bps           0bps/792bps         0/99
638 67.116.254.240  0bps/0bps           0bps/760bps         0/95
639 198.105.196.241 0bps/0bps           6.1kbps/57.7kbps    4795/18083
640 98.110.93.243   0bps/0bps           0bps/760bps         0/95
641 110.233.127.244 0bps/0bps           0bps/480bps         0/180
642 216.52.233.244  0bps/0bps           936bps/616bps       234/154
643 201.215.37.245  0bps/0bps           0bps/464bps         0/162
644 207.171.191.245 0bps/0bps           4.1kbps/22.7kbps    516/2849
645 82.2.232.245    0bps/0bps           0bps/880bps         0/268
646 94.18.131.246   0bps/0bps           0bps/1072bps        0/134
647 70.173.166.246  0bps/0bps           175.9kbps/5.2kbps   32070/852
648 122.172.163.247 0bps/0bps           384bps/0bps         48/0
649 198.105.196.248 0bps/0bps           0bps/2.1kbps        0/269
650 216.52.233.248  0bps/0bps           936bps/616bps       351/231
651 64.14.29.250    0bps/0bps           4.1kbps/9.0kbps     564/2228
652 98.136.48.250   0bps/0bps           1472bps/1216bps     184/152
653 98.136.48.251   0bps/0bps           1248bps/1312bps     208/164
654 184.73.164.251  0bps/0bps           320bps/368bps       80/46
655 67.174.8.252    0bps/0bps           456bps/416bps       153/148
656 67.252.153.252  0bps/0bps           4.3kbps/171.6kbps   9791/405706
657 76.174.7.253    0bps/0bps           1456bps/5.3kbps     316/759
658 94.245.121.253  0bps/0bps           672bps/0bps         168/0
659 216.16.244.253  0bps/0bps           0bps/11.5kbps       0/1487
660 68.142.93.254   0bps/0bps           1280bps/368bps      200/46
661 76.26.178.254   0bps/0bps           2.7kbps/2.9kbps     2334/5377
662 72.225.198.254  0bps/0bps           1248bps/480bps      156/60
663 96.6.205.254    0bps/0bps           0bps/712bps         0/178
664 255.255.255.255 0bps/0bps           744bps/0bps         93/0
[root@NICROS1] >
[root@NICROS1] >
Check with your ISP. Ask if they have a 10.25.200.x net on your wan interface. I have 10.2.144.1 on my wan. It is the Cox Communications router between Miramar Beach and Destin. My first hop on a traceroute to anywhere.
Try pinging 10.25.200.185. The icmp traffic will show over ether1. That means 10.25.200.185 is on your wan interface. Your ISP.
ADD: They probably have residential dhcp clients on that connection also. The 255.255.255.255 address in your list is a giveaway. That is a dhcp request ip. They just forward (route) your public ip through their private net.
If that is not enough to convince you, connect a computer directly to your ISP. Set it for dhcp instead of static. I will bet it gets a 10.25.200.x address.
Hey SurferTim,
Sorry about the delayed response, things got crazy for a bit. Anyway…
I checked with my ISP, they don’t use that IP range on their network.
Interestingly, my router died a while later. I replaced it with a routerboard 750G running ROS 4.5. At the same time I changed my internal IP address range from 10.25.200.x to 10.25.0.x.
Now I"m seeing traffic from 10.25.0.x addresses on the WAN port of my new router.
I also put in an identical router type and OS on my personal network - hooked up via DHCP to a different ISP, I"m seeing internal IPs on the WAN port of that one as well - http, bootps and boot pc (255.255.255.255)
Am I perpetually configuring something improperly, and carrying this mistake onto all my routers?
Where is your wan (internet connection) interface?
Maybe if you post “/ip firewall nat” would help.
This gets a little confusing with two sets of configurations here. It would be best if you start your own thread next time.
My apologies to the origonator of this thread. I meant to put in my own two cents, not take over.
Anyway, My WAN interface is ether 1- gateway, connected directly into the cable modem provided by my ISP
Ip firewall NAT is as follows
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=\
    ether1-gateway
add action=dst-nat chain=dstnat comment=RDP disabled=no dst-address=70.78.xxx.xxx dst-port=3389 protocol=\
    tcp to-addresses=192.168.1.109 to-ports=3389
add action=dst-nat chain=dstnat comment=Torrent disabled=no dst-address=70.78.xxx.xxx dst-port=62689 \
    protocol=tcp to-addresses=192.168.1.109 to-ports=62689
add action=dst-nat chain=dstnat comment=Pap2 disabled=no dst-address=70.78.xxx.xxx dst-port=5060 protocol=\
    udp to-addresses=192.168.1.109 to-ports=5060
add action=dst-nat chain=dstnat comment=Pap2tcp disabled=no dst-address=70.78.xxx.xxx dst-port=5060 \
    protocol=tcp to-addresses=192.168.1.109 to-ports=5060
[admin@MikroTik] /ip firewall nat>
This is for my home network. I figure that, if I’m having problems on all my setups, I’d use the simplist one as my example.
Torch shows IP addresses on a interface after applying NAT.
Hello Dear you can find you Result here under ,
UDP Ports 67 and 68
Common Use
Port 67 Bootps
Port 68 Bootpc
Inbound Scan
Typically this traffic is related to normal DHCP operation and is not an attack on your network. DHCP (Dynamic Host Configuration Protocol) is how your computer gets its unique IP address. When a system starts up on a network it must first request an IP address (assume it is not using a static IP address), and it does this by broadcasting a request to the DHCP server:
UDP 0.0.0.0:68 → 255.255.255.255:67
since the requesting system doesn’t have an IP address (why it is asking) it uses 0.0.0.0 and since its new to the network it doesn’t know where the DHCP server is, so it broadcasts the request to the entire network (255.255.255.255). On some networks you will see these requests bounce off of your firewall (depending on your provider’s network configuration and if your router/firewall logs these requests), or your firewall/router might log this traffic between it and your providers DHCP server when it is getting or renewing its WAN IP address.
The DHCP server then responds with something like:
UDP 192.168.1.1:67 → 255.255.255.255:68
This is typically a DHCP offer. NOTE it has to be broadcasted (255.255.255.255) as the requesting system doesn’t yet have an IP address (its contained in the offer). The data in this transmission contains the IP and other network configuration information that the requesting system needs to connect to the network (lease time, Subnet Mask, etc). Again on some networks you will see these bounce off of your firewall (depending on your provider’s network configuration and if your router/firewall logs these), or your firewall/router might log this traffic between it and your providers DHCP server when it is getting or renewing its WAN IP address.
Sometimes you will see something like:
UDP 192.168.1.101:67 → 192.168.1.1:68
as a request, followed by a reply
UDP 192.168.1.1:68 → 192.168.1.101:67
These are typically IP renewal requests, where a system has an IP address and is asking to renew it (ie get the lease extended), or if its not possible to renew the IP address to receive a new IP address from the DHCP server. Since the requesting system knows where the DHCP server is and it already has a current IP address the requests don’t need to use 0.0.0.0 and 255.255.255.255.
Outbound Scan
Most routers/firewalls don’t log this traffic, but given most routers/firewalls are also the local DHCP server you might see traffic logged between your router/firewall and connecting systems as they ask for and are assigned an IP Address on your network. It is not common to have your DHCP server on the WAN side of your firewall so in those cases perhaps you should investigate the configuration of your network.
