Weird Wifi connection
I have configured a 24port PoE switch to be both my switch and my router while waiting for my dedicated router this will do.
Connected to this switch I have a Cap AX.
I have 2 VLANs that I have setup.
COMPANY_VLAN
MGMT_VLAN
I have not configured any Hotspot on either the switch or the cap.
The cap presents me with two wifi SSIDs. One named company and one named MGMT.
The MGMT_VLAN is set to id 99
COMPANY_VLAN is set to id 10.
At the moment both have the same access to internet but only MGMT has access to Winbox and neighbours.
When I connect to company wifi, I put in my key and it works.
When I connect to MGMT wifi, I put in my key and it works but Windows insist on me to open my browser and login to get access.
I thought that perhaps I had made a mistake and somehow activated Hotspot so I did a reset and started over but I get the same issue.
Anybody with an idea here?
without seeing your configuration nobody can tell
Can you also post the config of the cAP AX?
If you post it in between code tags (by using the </> button), it will become more readable.
Ofcourse, how embarrassing of me :frowning:.
The config of the firewall:
add ingress-filtering=no name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] mac-address=48:A9:8A:C0:49:E0
/interface vlan
add interface=bridge name=COMPANY_VLAN vlan-id=10
add interface=bridge name=MGMT_VLAN vlan-id=99
add name=COMPANY_LAN
add name=MGMT_LAN
add name=WAN
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.77.50-192.168.77.254
add name=dhcp_pool1 ranges=10.20.26.2-10.20.26.254
add address-pool=dhcp_pool0 interface=COMPANY_VLAN name=dhcp1
add address-pool=dhcp_pool1 interface=MGMT_VLAN name=dhcp2
/port
set 0 name=serial0
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether2
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
    interface=ether12 pvid=10
    interface=ether14 pvid=10
    interface=ether20 pvid=10
    interface=ether22 pvid=10
    interface=ether24 pvid=99
    interface=ether3 pvid=10
set discover-interface-list=MGMT_LAN
/interface bridge vlan
add bridge=bridge tagged=bridge,ether2 untagged=ether24 vlan-ids=99
add bridge=bridge tagged=bridge,ether2 untagged=\
    ether3,ether12,ether14,ether20,ether22 vlan-ids=10
add interface=COMPANY_VLAN list=COMPANY_LAN
add interface=MGMT_VLAN list=MGMT_LAN
add interface=ether1 list=WAN
add address=192.168.77.1/24 interface=COMPANY_VLAN network=192.168.77.0
add address=10.20.26.1/24 interface=MGMT_VLAN network=10.20.26.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add address=10.20.26.0/24 dns-server=10.20.26.1 gateway=10.20.26.1
add address=192.168.77.0/24 dns-server=192.168.77.1 gateway=192.168.77.1
set allow-remote-requests=yes
add action=accept chain=input connection-state=established,related
add action=accept chain=input in-interface=ether23
add action=accept chain=input in-interface-list=MGMT_LAN
add action=accept chain=input dst-port=53 in-interface-list=COMPANY_LAN \
    protocol=tcp
    protocol=udp
add action=drop chain=input
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward in-interface-list=MGMT_LAN
add action=accept chain=forward in-interface-list=COMPANY_LAN \
    out-interface-list=WAN
add action=drop chain=forward
add action=dst-nat chain=dstnat dst-port=80 protocol=tcp to-addresses=\
    192.168.77.2 to-ports=80
add action=dst-nat chain=dstnat dst-port=5510 protocol=tcp to-addresses=\
    192.168.77.2 to-ports=5510
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os
/tool mac-server
set allowed-interface-list=MGMT_LAN
/tool mac-server mac-winbox
The config of the cap:
I’m a bit confused about this part of this config:
/ip hotspot service-port
set ftp disabled=yes
I have not enabled or set any hotspot service on either device at all but perhaps this is some default setting here :slight_smile:.
add name=bridge vlan-filtering=yes
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=all \
    configuration.country="hidden" .mode=ap .ssid=MGMT5 disabled=no \
    security.authentication-types=wpa2-psk,wpa3-psk .passphrase=MGMTMGMT
set [ find default-name=wifi2 ] configuration.country="hidden" .mode=ap .ssid=\
    MGMT disabled=no security.authentication-types=wpa2-psk,wpa3-psk \
/interface vlan
/interface wifi
add configuration.mode=ap .ssid=company5 disabled=no mac-address=\
    4A:A9:8A:C0:3F:5A master-interface=wifi1 name=COMPANY_WIFI \
    security.authentication-types=wpa2-psk,wpa3-psk .passphrase=hiddenofcourse
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1
    interface=wifi1 pvid=99
    interface=wifi2 pvid=99
    interface=COMPANY_WIFI pvid=10
add bridge=bridge tagged=bridge,ether1 untagged=wifi1 vlan-ids=99
add bridge=bridge tagged=bridge,ether1 untagged=COMPANY_WIFI vlan-ids=10
/ip dhcp-client
/system clock
set time-zone-name="hidden"
/system note
What???
After I added the following to get my port forward to work:
add action=accept chain=forward connection-nat-state=dstnat
It now works. I no longer get the question to open my browser.
What is this? Perhaps have something to do with the port forward on port 80?
I need to do some tests here :stuck_out_tongue:
