i tired to edit settings of my web-proxy and not work…
i configer my web-proxy to cache sites and files to speed up my browsing of my network but it’s slow it
when i blocked or redirect any url it’s work fine
when i see cache contents i found all my files
but when i try to download any file from cache it’s so so slow
I think what Chupaka means to say is: If you limit your client’s download (with PPoE interface) ALL traffic has to obey. The interface doesn’t know if a file comes from the internet or from proxy…
I don’t have so much experiance with web-proxy and PPoE but I presume that if you want content from the proxy to download with the full network speed to the customer while his internet access is limited you have to put the proxy inside the LAN network. So client downloads from router with full speed and only if proxy can’t fulfill demand and needs new (updated) file from internet THAT connection is made to the internet, where you want that that client is limited.
I don’t think that is possible within one router. The PPoe interface is last what download traffic ´sees´ from router, and it is limited there…
Chupaka, correct me if I’m wrong. I jumped in to see if my line of thinking is right in this…
i need advice.
i am running router OS on pc, processor speed is 2.8, memory=512, hard disk=40gig , i use hotspot running on the lan with maximum of 40 clients running at once. i want to use transparent web proxy and dns cache. (please advice).
TheProgrammer, you need to pick cached files out, by DSCP field value (see Cache Hit DSCP in WebProxy settings) and send them to another queue (for example, mark-packet for appropriate DSCP, and then create another simple queue with packet-mark=your_hit_mark and high limits, then place it on top of all simple queues)
collins465, doesn’t Hotspot use WebProxy by default? there’s a ‘Transparent Proxy’ checkbox in Hotspot User Profile
