Westminister Chimes
Past this in the routers Terminal to have Westminister Chimes through the speaker.
/system script
add name=“Westminister” source=“:global c 11:00:00\r\n:global h 0\r\n:global m 0\r\n:global s 0\r\n:set c [/system clock get time]\r\n:set h [ :tonum [:pick $c 0 2]]\r\n:set m [ :tonum [:pick $c 3 5]]\r\n:set s [ :tonum [:pick $c 6 8]]\r\n\r\n# First-quarter Sequence 1\r\n:if ( $m=15 ) do /system script run "Westminister Seq #1"}\r\n# Half-hour Sequence 2,3\r\n:if ( $m = 30 ) do {/system script run "Westminister Seq #2"}\r\n:if ( $m = 30 ) do {:delay 2500ms}\r\n:if ( $m = 30 ) do /system script run "Westminister Seq #3"}\r\n\r\n# Third-quarter Sequence 4,5,1\r\n:if ( $m = 45 ) do {/system script run "Westminister Seq #4"}\r\n:if ( $m = 45 ) do {:delay 2500ms}\r\n:if ( $m = 45 ) do {/system script run "Westminister Seq #5"}\r\n:if ( $m = 45 ) do {:delay 2500ms}\r\n:if ( $m = 45 ) do {/system script run "Westminister Seq #1"}\r\n\r\n# Full-hour Sequence 2,3,4,5\r\n:if ( $m=0 ) do {/system script run "Westminister Seq #2"}\r\n:if ( $m=0 ) do {:delay 2500ms}\r\n:if ( $m=0 ) do {/system script run "Westminister Seq #3"}\r\n:if ( $m=0 ) do {:delay 2500ms}\r\n:if ( $m=0 ) do {/system script run "Westminister Seq #4"}\r\n:if ( $m=0 ) do {:delay 2500ms}\r\n:if ( $m=0 ) do {/system script run "Westminister Seq #5"}\r\n:if ( $m=0 ) do {:delay 2500ms}\r\n:if ( $m=0 ) do {/system script run "Westminister Chime"}”
add name=“Westminister Chime” source=“#Westminister Chime\r\n#Chimes the number of times that the hour is.\r\n\r\n:global ch 6\r\n:set ch [:tonum($h)]\r\n:if ($ch>12) do={:set ch ($ch - 12)}\r\n:if ($ch=0) do={:set ch ($ch + 12)}\r\n:for i from=1 to $ch step=1 do {:beep length=1000ms frequency=440; :delay 1500ms}”
add name=“Westminister Seq #1” source=“#Westminister Sequence #1\r\n# E-660 D-588 C-528 G-396\r\n# EDCG\r\n:beep length=480ms frequency=660\r\n:delay 500ms\r\n:beep length=480ms frequency=588\r\n:delay 500ms\r\n:beep length=480ms frequency=528\r\n:delay 500ms\r\n:beep length=480ms frequency=396\r\n:delay 10000ms”
add name=“Westminister Seq #2” source=“#Westminister Sequence #2\r\n# E-660 D-588 C-528 G-396\r\n# CEDG\r\n:beep length=480ms frequency=528\r\n:delay 500ms\r\n:beep length=480ms frequency=660\r\n:delay 500ms\r\n:beep length=480ms frequency=588\r\n:delay 500ms\r\n:beep length=480ms frequency=396\r\n:delay 10000ms”
add name=“Westminister Seq #3” source=“#Westminister Sequence #3\r\n# E-660 D-588 C-523 G-396\r\n# CDEC\r\n:beep length=480ms frequency=523\r\n:delay 500ms\r\n:beep length=480ms frequency=588\r\n:delay 500ms\r\n:beep length=480ms frequency=659\r\n:delay 500ms\r\n:beep length=480ms frequency=528\r\n:delay 10000ms”
add name=“Westminister Seq #4” source=“#Westminister Sequence #4\r\n# E-660 D-588 C-528 G-396\r\n# ECDG\r\n:beep length=480ms frequency=660\r\n:delay 500ms\r\n:beep length=480ms frequency=528\r\n:delay 500ms\r\n:beep length=480ms frequency=588\r\n:delay 500ms\r\n:beep length=480ms frequency=396\r\n:delay 10000ms”
add name=“Westminister Seq #5” source=“#Westminister Sequence #5\r\n# E-660 D-588 C-528 G-396\r\n# GDEC\r\n:beep length=480ms frequency=396\r\n:delay 500ms\r\n:beep length=480ms frequency=588\r\n:delay 500ms\r\n:beep length=480ms frequency=660\r\n:delay 500ms\r\n:beep length=480ms frequency=528\r\n:delay 10000ms”
/ system scheduler
add name=“Westminister” on-event=Westminister start-date=jan/01/1970 start-time=00:00:00 interval=15m comment=“” disabled=no
wow nice!!!
There are a couple of errors in the script. Can you figure it out?
Here’s a new copy with the corrections that I did.
/system script
add name=“Westminister” source=“:global c 11:00:00\r\n:global h 0\r\n:global m 0\r\n:global s 0\r\n:set c [/system clock get time]\r\n:set h [ :tonum [:pick $c 0 2]]\r\n:set m [ :tonum [:pick $c 3 5]]\r\n:set s [ :tonum [:pick $c 6 8]]\r\n\r\n# First-quarter Sequence 1\r\n:if ( $m=15 ) do {/system script run "Westminister Seq #1"}\r\n\r\n# Half-hour Sequence 2,3\r\n:if ( $m = 30 ) do {/system script run "Westminister Seq #2"}\r\n:if ( $m = 30 ) do {:delay 2500ms}\r\n:if ( $m = 30 ) do {/system script run "Westminister Seq #3"}\r\n\r\n# Third-quarter Sequence 4,5,1\r\n:if ( $m = 45 ) do {/system script run "Westminister Seq #4"}\r\n:if ( $m = 45 ) do {:delay 2500ms}\r\n:if ( $m = 45 ) do {/system script run "Westminister Seq #5"}\r\n:if ( $m = 45 ) do {:delay 2500ms}\r\n:if ( $m = 45 ) do {/system script run "Westminister Seq #1"}\r\n\r\n# Full-hour Sequence 2,3,4,5\r\n:if ( $m=0 ) do {/system script run "Westminister Seq #2"}\r\n:if ( $m=0 ) do {:delay 2500ms}\r\n:if ( $m=0 ) do {/system script run "Westminister Seq #3"}\r\n:if ( $m=0 ) do {:delay 2500ms}\r\n:if ( $m=0 ) do {/system script run "Westminister Seq #4"}\r\n:if ( $m=0 ) do {:delay 2500ms}\r\n:if ( $m=0 ) do {/system script run "Westminister Seq #5"}\r\n:if ( $m=0 ) do {:delay 2500ms}\r\n:if ( $m=0 ) do {/system script run "Westminister Chime"}”
/ system scheduler
That didn’t paste properly for me so I’ve reformated it here
/ system scheduler
add name="Westminister" on-event=Westminister start-date=jan/01/1970 start-time=00:00:00 interval=15m comment="" disabled=no
/system script
add name="Westminister Seq #2" policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff source="#Westminis\
    ter Sequence #2\r\
    \n# CEDG\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 10000ms"
add name="Westminister Seq #3" policy=\
    ter Sequence #3\r\
    \n# CDEC\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 10000ms"
add name="Westminister Seq #4" policy=\
    ter Sequence #4\r\
    \n# ECDG\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 10000ms"
add name="Westminister Seq #5" policy=\
    ter Sequence #5\r\
    \n# GDEC\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 10000ms"
add name=Westminister policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff source=":global c \
    11:00:00\r\
    \n:global h 0\r\
    \n:global m 0\r\
    \n:global s 0\r\
    \n:set c  [/system clock get time ]\r\
    \n:set h  [ :tonum  [:pick  \$c 0 2 ] ]\r\
    \n:set m  [ :tonum  [:pick  \$c 3 5 ] ]\r\
    \n:set s  [ :tonum  [:pick  \$c 6 8 ] ]\r\
    \n\r\
    \n:if  (  \$m=15 ) do {/system script run  \"Westminister Seq #1\"}\r\
    \n\r\
    \n:if  (  \$m = 30  ) do {/system script run  \"Westminister Seq #2\"}\r\
    \n:if  (  \$m = 30  ) do {:delay 2500ms}\r\
    \n:if  (  \$m = 30  ) do {/system script run  \"Westminister Seq #3\"}\r\
    \n\r\
    \n:if  (  \$m = 45  ) do {/system script run  \"Westminister Seq #4\"}\r\
    \n:if  (  \$m = 45  ) do {:delay 2500ms}\r\
    \n:if  (  \$m = 45  ) do {/system script run  \"Westminister Seq #5\"}\r\
    \n:if  (  \$m = 45  ) do {/system script run  \"Westminister Seq #1\"}\r\
    \n\r\
    \n:if  (  \$m=0  ) do {/system script run  \"Westminister Seq #2\"}\r\
    \n:if  (  \$m=0  ) do {:delay 2500ms}\r\
    \n:if  (  \$m=0  ) do {/system script run  \"Westminister Seq #3\"}\r\
    \n:if  (  \$m=0  ) do {/system script run  \"Westminister Seq #4\"}\r\
    \n:if  (  \$m=0  ) do {/system script run  \"Westminister Seq #5\"}\r\
    \n:if  (  \$m=0  ) do {/system script run  \"Westminister Chime\"}\r\
    \n"
add name="Westminster Chime" policy=\
    ter Chime\r\
    \n\r\
    \n:global ch 6\r\
    \n:set ch  [:tonum ( \$h ) ]\r\
    \n:if  ( \$ch>12 ) do= {:set ch  ( \$ch - 12 ) }\r\
    \n:if  ( \$ch=0 ) do= {:set ch  ( \$ch + 12 ) }\r\
    \n:for i from=1 to  \$ch step=1 do  {:beep length=1000ms frequency=440; :d\
    elay 1500ms }\""
Did not work for me on a 133 running 3.20. Had to modify the script some, mostly in the chime and delays.
edit Corrected the chime /edit
/system script
add name="Westminister Seq #1" policy=\
    ter Sequence #1\r\
    \n# EDCG\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:beep length=480ms frequency=396"
    ter Sequence #2\r\
    \n# CEDG\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    ter Sequence #3\r\
    \n# CDEC\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:beep length=480ms frequency=528"
    ter Sequence #4\r\
    \n# ECDG\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n"
    ter Sequence #5\r\
    \n# GDEC\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
    \n:delay 500ms\r\
add name="Westminister Chime" policy=\
    ftp,reboot,read,write,policy,test,winbox,password source="#Westminister Ch\
    ime\r\
    \n:global h\r\
    \n:global ch\r\
    \n:if  ( \$h >12 ) do= {\r\
    \n:set ch  ( \$h - 12 )\r\
    \n:};\r\
    \n:if  ( \$h < 12 ) do= {\r\
    \n:set ch \$h\r\
    \n:}\r\
    \n:if  ( \$h=0 ) do= {\r\
    \n:set ch  ( \$h + 12 )\r\
    \n:}\r\
    \n\r\
    \n:for i from=1 to=\$ch step=1 do={\r\
    \n:beep length=1000ms frequency=440;\r\
    \n:delay 2000ms\r\
    \n:}"
    11:00:00\r\
    \n:global h 0\r\
    \n:global m 0\r\
    \n:global s 0\r\
    \n\r\
    \n#Really should put a limiter in here so it does not chime all night long\
     when no one is around to hear it.\r\
    \n\r\
    \n\r\
    \n:if  (  \$m = 30  ) do { :delay 2000ms }\r\
    \n\r\
    \n:if  (  \$m = 45  ) do { :delay 2000ms }\r\
    \n\r\
    \n:if  (  \$m = 0  ) do {/system script run  \"Westminister Seq #2\"}\r\
    \n:if  (  \$m = 0  ) do { :delay 2000ms }\r\
    \n:if  (  \$m = 0  ) do {/system script run  \"Westminister Seq #3\"}\r\
    \n:if  (  \$m = 0  ) do {/system script run  \"Westminister Seq #4\"}\r\
    \n:if  (  \$m = 0  ) do {/system script run  \"Westminister Seq #5\"}\r\
    \n:if  (  \$m = 0  ) do {/system script run  \"Westminister Chime\"}\r\
    \n:if  (  \$m = 0  ) do { :delay 2000ms }"
