TL;DR:
It’s going to be a pain to renumber your network no matter when you do it. Do it now, and do it via a planned scheme that works for your growth needs that will make your life magnitudes easier in the future.
Full response:
Sorry, but there’s no way around fixing your numbering - at least not without gumming things up with more work-arounds that may come back to bite you in the long run.
Some short term fixes might be to
- create a guest WiFi segment and move your phones/tablets/etc onto that segment, leaving the printers and LAN stuff alone for now.
- shorten the lease duration so that transient devices like those above won’t take up space for long after they’re gone.
However, those short term fixes can quickly become permanent and make your network snowball into a spaghetti bowl nightmare.
If you have a growing organization, then I highly recommend that you switch to using 10.x.x.x as your private IP space. I previously worked at an enterprise where 192.168.x.x had been used since the beginning. The organization went through explosive growth, and the original site1 = 192.168.1.x , site2 = 192.168.2.x , etc scheme was vastly outgrown. There were all sorts of random 192.168.x.x networks at every site w/o rhyme or reason. They weren’t contiguous blocks; either by site or by functionality. 192.168.14.x may be a server net at site 3, while .13.x was a guest network at site 1 and .15.x was a workstation LAN at site 1 again.
I implemented a numbering scheme as follows:
10.x.x.x gets divided up by sites, so 10.1.0.0/16 is site1, 10.2.0.0/16 is site 2, etc.
The routers all had loopback IP addresses of 192.168.255.x/32, so I used the 4th octet of the loopback IP to dictate the site numbers in the new scheme.
This gives 256 /24 networks at each site. I then defined certain maps for the various uses of those networks as well:
Say 10.x.0-15.x would be server networks, 10.x.16-31 would be network management, etc.
Even small sites having only 12 seats would still follow this same scheme.
That way, we could tell at a glance what an IP address was just by looking at the 2nd and 3rd octets.
(What’s even better is that this mapping can be easily copied 1:1 when laying out IPv6. Dole out a /48 of IPv6 for each /16 of 10.x.x.x space and you’re done.)
In your case, I would say that the large site needs one of two things to happen:
- split your LAN into two segments, with each using its own /24
or
- create a supernet (/23 /22 etc) from available space in the 192.168.x.x range and renumber your large site into this supernet.
If you’re going to go through the trouble of renumbering, you may as well use the 10.x.x.x mapping strategy though, so that you can scale for years w/o running out of addressing.
Note that my scheme was based on the idea that we would never have more than 256 campuses, and that each would tend to be relatively large, requiring hundreds or thousands of seats (we ran call centers). If you would have more sites, but smaller, then you could give less than a /16 to each site so that more sites are available in your scheme.
e.g.
10.0.0.0/20 = site 1,
10.0.16.0/20 = site2,
10.0.24.0/20 = site3
etc.
Then you can break these /20s into smaller allocations at each site just as you would if giving a full /16 per site.
