Hello everyone,
I was trying to setup the wireguard server on my mikrotik device, so that I could access my local network remotely. I almost succeeded, I can make a connection from my external device to the mikrotik router and successfully ping it, but I cannot ping any other device on the local network. When looking at the packet counter in the firewall, I can see the packets reaching the forward rule, so the problem might be when they try to reach back to the remote device?
To my surprise, it works the other way around (I can ping the remote device 192.168.87.2 from my local network machine at 192.168.88.26). Any help and/or suggestion on improving my router configuration is appreciated!
Please find the network diagram and router config export attached below. The wireguard in question is the one with rw-wg name.
# 2025-04-23 21:37:00 by RouterOS 7.17
# model = RB750Gr3
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
/interface wireguard
add listen-port=33627 mtu=1420 name=rw-wg
add listen-port=13231 mtu=1420 name=wireguard-pia
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/ip smb users
/port
set 0 name=serial0
/queue type
add kind=pcq name=LimitDownload pcq-classifier=dst-address pcq-rate=150M
add kind=pcq name=LimitUpload pcq-classifier=src-address pcq-rate=100M
/queue simple
add comment="Limit UP/DOWN based on PCQ queue type" name=queue1 queue=\
LimitUpload/LimitDownload target=192.168.88.0/24
/routing table
add disabled=no fib name=PIA
/system logging action
set 3 remote=192.168.88.117 src-address=192.168.88.1
add bsd-syslog=yes name=RemoteError remote=192.168.88.117 src-address=\
192.168.88.1 syslog-severity=error target=remote
add bsd-syslog=yes name=RemoteWarning remote=192.168.88.117 src-address=\
192.168.88.1 syslog-severity=warning target=remote
add bsd-syslog=yes name=RemoteInfo remote=192.168.88.117 src-address=\
192.168.88.1 syslog-severity=info target=remote
add bsd-syslog=yes name=RemoteCritical remote=192.168.88.117 src-address=\
192.168.88.1 syslog-severity=critical target=remote
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
set udp-timeout=10s
set discover-interface-list=none
/ipv6 settings
/interface ovpn-server server
add auth=sha1,md5 mac-address=XX:XX:XX:XX:XX:XX name=ovpn-server1
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=xxx.xxx.xxx.xxx endpoint-port=\
xxxx interface=wireguard-pia name=peer1 persistent-keepalive=25s \
public-key="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
add allowed-address=192.168.87.2/32 interface=rw-wg \
name=peer3 private-key="xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" \
public-key="xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
192.168.88.0
add address=xxx.xxx.xxx.xxx interface=wireguard-pia network=xxx.xxx.xxx.0
add address=192.168.87.1/24 interface=rw-wg network=192.168.87.0
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=9.9.9.9 gateway=\
192.168.88.1
set servers=9.9.9.9
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept established,related" \
invalid
"Allow incoming wireguard RW connection" dst-port=33627 log=yes \
log-prefix=wg-rw- protocol=udp
in-interface-list=!LAN
disabled=yes ipsec-policy=in,ipsec
disabled=yes ipsec-policy=out,ipsec
"allow traffic from server to PIA VPN" out-interface=wireguard-pia \
src-address=192.168.88.117
"Allow access to internal network from RW WG" dst-address=192.168.88.0/24 \
in-interface=rw-wg
add action=accept chain=forward comment="Allow from GoogleTV allow list" \
dst-address-list="GoogleTV Allowed" src-address=192.168.88.41
"Drop any other communication from GoogleTV" src-address=192.168.88.41
connection-state=established,related dst-address-list=\
"MPC,VPC,MS, MM, VM" hw-offload=yes
established,related,untracked
connection-state=invalid log=yes log-prefix=invalid
"Drop packets from LAN that do not have LAN IP" in-interface=bridge log=\
yes log-prefix=LAN_!LAN src-address=!192.168.88.0/24
add action=masquerade chain=srcnat out-interface=wireguard-pia src-address=\
192.168.88.117
/ip firewall service-port
set ftp disabled=yes
/ip ipsec profile
add disabled=no distance=10 dst-address=0.0.0.0/0 gateway=wireguard-pia \
pref-src=0.0.0.0 routing-table=PIA scope=30 suppress-hw-offload=no \
target-scope=10
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh address=192.168.88.0/24
set www-ssl address=192.168.88.0/24 certificate=pubkey disabled=no
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/ip ssh
set strong-crypto=yes
/routing bfd configuration
add disabled=no
/routing rule
add action=lookup-only-in-table disabled=no src-address=192.168.88.117/32 \
table=PIA
/system identity
set name=RouterOS
/system logging
add action=RemoteInfo prefix=mikrotik topics=info
add action=RemoteError prefix=mikrotik topics=error
add action=RemoteInfo prefix=mikrotik topics=firewall
add action=RemoteCritical prefix=mikrotik topics=critical
add action=RemoteWarning disabled=yes prefix=vlg topics=firewall
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/tool netwatch
add disabled=yes down-script=\
"/ip dhcp-server/network/set 0 dns-server=9.9.9.9" host=192.168.88.117 \
http-codes="" interval=30s test-script="" type=simple up-script=\
"/ip dhcp-server/network/set 0 dns-server=192.168.88.117"
