Hi I need an antenna for client, I am looking for some very small antenna, but with high gain to get good signal. Client has some trees in the way. I need to get him quality link without disconnecting. The distance is about 700m, three trees in the way. What mini-pci card is best to use, there are only two small networks in location, but that trees.
Gain is proportional to size. If you want more gain it typically means a larger antenna. It would help it you put what gain you are looking for and what size antenna is desired…
Scott
