I have Mikrotik RouterOS v4.13 with hotspot. Here are the firewall rules that I got from /ip firewall filter print. Please tell me of the rules that I need to remove and any extra that I should add:
chain=input action=drop protocol=tcp dst-port=22,23,80,443,8728
4 X ;;; Reject if in the 24-hour-list
chain=forward action=reject reject-with=icmp-network-unreachable
src-address-list=24-hour-list dst-address-list=0.0.0.0
5 I ;;; Check if dest is an open customer
chain=forward action=jump jump-target=open-customers
dst-address-list=open-customers
6 I ;;; Check Known Bad Hosts
chain=forward action=jump jump-target=bad-hosts
7 X ;;; Reject if in the 24-hour-list
8 ;;; Take no action on bogons
chain=bad-host-detection action=return src-address-list=bogons
9 ;;; Add to the 24 hours list
chain=bad-host-detection action=add-src-to-address-list protocol=udp
src-address=192.168.2.0/24 dst-address=192.168.2.0/24
address-list=24-hour-list address-list-timeout=1d src-port=137
dst-port=137
10 chain=bad-host-detection action=return
11 ;;; jump to the bad-host-detection chain
chain=forward action=jump jump-target=bad-host-detection
src-address-list=!our-networks
12 ;;; jump to the bad-host-detection chain
13 X ;;; log and reject the rest
chain=forward action=log log-prefix=""
14 chain=forward action=accept protocol=tcp dst-port=1863
15 chain=forward action=accept protocol=tcp dst-port=443
16 chain=output action=drop protocol=udp src-port=5678
17 ;;; ADD to address-list src-conficker
chain=forward action=add-src-to-address-list dst-address-list=conficker
address-list=src-conficker address-list-timeout=3d
18 I chain=forward action=jump jump-target=drop src-address-list=local-addr
dst-address-list=local-addr in-interface=lan out-interface=lan
19 I chain=input action=jump jump-target=drop src-address=192.168.2.0/24
src-address-type=broadcast dst-address-type=local
src-address-list=local-addr in-interface=lan
20 I chain=forward action=jump jump-target=drop src-address=192.168.2.0/24
21 ;;; Port scanners to list
chain=forward action=add-src-to-address-list protocol=tcp psd=21,3s,3,1
address-list=port scanners address-list-timeout=2w
22 ;;; NMAP FIN Stealth scan
tcp-flags=fin,!syn,!rst,!psh,!ack,!urg protocol=tcp
23 ;;; SYN/FIN scan
chain=forward action=add-src-to-address-list tcp-flags=fin,syn
protocol=tcp address-list=port scanners address-list-timeout=2w
24 ;;; SYN/RST scan
chain=forward action=add-src-to-address-list tcp-flags=syn,rst
25 ;;; FIN/PSH/URG scan
tcp-flags=fin,psh,urg,!syn,!rst,!ack protocol=tcp
26 ;;; ALL/ALL scan
tcp-flags=fin,syn,rst,psh,ack,urg protocol=tcp
27 ;;; NMAP NULL scan
tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg protocol=tcp
28 ;;; dropping port scanners
chain=forward action=drop src-address-list=port scanners
29 ;;; allow established connections
chain=forward action=accept connection-state=established
30 ;;; allow related connections
chain=forward action=accept connection-state=related
31 ;;; drop invalid connections
chain=forward action=drop connection-state=invalid
32 ;;; Drop Blaster Worm
chain=virus action=drop protocol=tcp dst-port=135-139
33 ;;; Drop Messenger Worm
chain=virus action=drop protocol=udp dst-port=135-139
34 ;;; Drop Blaster Worm
chain=virus action=drop protocol=tcp dst-port=445
35 ;;; Drop Blaster Worm
chain=virus action=drop protocol=udp dst-port=445
36 ;;; ________
chain=virus action=drop protocol=tcp dst-port=593
37 ;;; ________
chain=virus action=drop protocol=tcp dst-port=1024-1030
38 ;;; Drop MyDoom
chain=virus action=drop protocol=tcp dst-port=1080
40 ;;; ndm requester
chain=virus action=drop protocol=tcp dst-port=1363
41 ;;; ndm server
chain=virus action=drop protocol=tcp dst-port=1364
42 ;;; screen cast
chain=virus action=drop protocol=tcp dst-port=1368
43 ;;; hromgrafx
chain=virus action=drop protocol=tcp dst-port=1373
44 ;;; cichlid
chain=virus action=drop protocol=tcp dst-port=1377
45 ;;; Worm
chain=virus action=drop protocol=tcp dst-port=1433-1434
46 ;;; Bagle Virus
chain=virus action=drop protocol=tcp dst-port=2745
47 ;;; Drop Dumaru.Y
chain=virus action=drop protocol=tcp dst-port=2283
48 ;;; Drop Beagle
chain=virus action=drop protocol=tcp dst-port=2535
49 ;;; Drop Beagle.C-K
50 ;;; Drop MyDoom
chain=virus action=drop protocol=tcp dst-port=3127-3128
51 ;;; Drop Backdoor OptixPro
chain=virus action=drop protocol=tcp dst-port=3410
52 ;;; Worm
chain=virus action=drop protocol=udp dst-port=4444
53 ;;; Worm
chain=virus action=drop protocol=tcp dst-port=4444
54 ;;; Drop Sasser
chain=virus action=drop protocol=tcp dst-port=5554
55 ;;; Drop Beagle.B
chain=virus action=drop protocol=tcp dst-port=8866
56 ;;; Drop Dabber.A-B
chain=virus action=drop protocol=tcp dst-port=9898
57 ;;; Drop Dumaru.Y
chain=virus action=drop protocol=tcp dst-port=10000
58 ;;; Drop MyDoom.B
chain=virus action=drop protocol=tcp dst-port=10080
59 ;;; Drop NetBus
chain=virus action=drop protocol=tcp dst-port=12345
60 ;;; Drop Kuang2
chain=virus action=drop protocol=tcp dst-port=17300
61 ;;; Drop SubSeven
chain=virus action=drop protocol=tcp dst-port=27374
62 ;;; Drop PhatBot, Agobot, Gaobot
chain=virus action=drop protocol=tcp dst-port=65506
63 ;;; jump to the virus chain
chain=forward action=jump jump-target=virus
64 ;;; Allow HTTP
chain=forward action=accept protocol=tcp dst-port=80
65 ;;; Allow SMTP
chain=forward action=accept protocol=tcp dst-port=25
66 ;;; allow ping
chain=forward action=accept protocol=icmp
67 ;;; allow TCP
68 ;;; allow udp
chain=forward action=accept protocol=udp
69 ;;; drop everything else
70 ;;; drop ftp brute forcers
chain=input action=drop protocol=tcp src-address-list=ftp_blacklist
dst-port=21
71 chain=output action=accept protocol=tcp content=530 Login incorrect
dst-limit=1/1m,9,dst-address/1m
72 chain=output action=add-dst-to-address-list protocol=tcp
address-list=ftp_blacklist address-list-timeout=3h
73 ;;; drop ssh brute forcers
chain=input action=drop protocol=tcp src-address-list=ssh_blacklist
dst-port=22
74 chain=input action=add-src-to-address-list connection-state=new
protocol=tcp src-address-list=ssh_stage3 address-list=ssh_blacklist
address-list-timeout=1w3d dst-port=22
75 ;;; drop ssh brute downstream
chain=forward action=drop protocol=tcp src-address-list=ssh_blacklist
dst-port=22
76 chain=pre-hs-input action=drop protocol=tcp dst-port=64872-64875
connection-limit=5,32
77 chain=pre-hs-input action=drop protocol=tcp dst-port=64872-64875
connection-limit=100,24
78 chain=input action=accept protocol=icmp limit=50/5s,2
79 ;;; Drop Traceroute
chain=forward action=drop protocol=icmp icmp-options=11:0
80 ;;; Drop Traceroute
chain=forward action=drop protocol=icmp icmp-options=3:3
I have disabled the rules with I since they are invalid (I just disable them because you might give correction)
