I am setting some pretty straightforwart static routing on MT board, and ther eis one route that stays inactive for no apparent reason (at least I do not see any).
Rout may be inactive because there is other route with the sam scope but lower distance, thus having higher priority. Also, id static route is set but interface is inactive, that route will be inactive. Are there other reasons for static route to be inactive?
Here is my routing table
[me@MT] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE ROUTING-MARK
0 A S 0.0.0.0/0 reachable 188.12.128.1 1 wan-1 wan-1-route
1 A S 0.0.0.0/0 reachable 192.168.1.1 1 wan-2 wan-2-route
2 A S 0.0.0.0/0 reachable 80.174.164.249 1 pppoe-1 pppoe-1-route
3 S 0.0.0.0/0 reachable 10.80.0.1 1 pptp-1 pptp-1-route
4 DS 0.0.0.0/0 reachable 192.168.1.1 15 wan-2
5 ADS 0.0.0.0/0 reachable 188.12.128.1 10 wan-1
6 A S 10.216.0.0/16 reachable 10.216.6.33 1 llnk-21
7 ADC 10.216.6.32/29 10.216.6.34 0 llnk-21
8 A S 10.231.0.0/16 reachable 10.216.6.33 1 llnk-21
9 A S 10.50.10.0/24 reachable 10.216.6.33 1 llnk-21
10 ADC 10.80.0.1/32 10.80.0.2 0 pptp-1
11 ADC 80.174.164.249/32 81.118.55.48 0 pppoe-1
12 ADC 188.12.128.0/22 188.12.129.109 0 wan-1
13 ADC 192.168.1.0/24 192.168.1.2 0 wan-2
There are two routes that are inactive. Route #4 is obvious, there is route #5 withthe same scope but shorter distance.
But, I have problem with route #3, it stays inactive no matter what I do. I checked gateway, it is pingable. There are no routes with the same scope and the same routing-mark. I see no reason why it should not be active.
Can someone exerienced check it out. Maybe I am overlooking something.
