Before v7 is released we would like to optimize v6 routing.
Anyone who have performance issues with BGP, please describe in details what setup you are running and detailed problem description:
how many peers;
how many routes in routing table;
is there also OSPF,MPLS, VPLS, RIP etc running on the router;
what are the hardware specs;
are there routing filters;
average BGP update rate from upstream peers;
average amount of traffic forwarded over the router;
are there frequent BGP bgp peer flaps,
any other info that is relevant to routing and can be useful for optimization.
CCR1036-12G-4S
RouterOS: 6.20 → 6.22 → 6.23 → 6.24 → 6.25 SFP not working at all → 6.24 again → 6.27
No one single problem or performance issue on BGP.
The only problem I haved (for me fixed on 6.27) with the machine (and also with it’s VRRP mirror) is the SFP driver not auto-sensing rightly.
Too much often BGP peer freeze not for the BGP itself, but for the poor quality of SFP link with S-85DLC05D 850nm
Now, with the 6.27 this problem is vanished (I never try 6.26).
MRZ, I’d say other than the single threaded process of evaluating routes/loading routes from the BGP RIB-IN to RIB LOCAL I don’t think I’ve had any problem come up.
Obviously more BGP address families would be nice but, that’s not really to the point of your question
CCR1036’s, 11~ BGP peers, about 15k~ routes, although Im purposely not taking full table as the time to LOAD the table takes too much, and filtering through the routetable takes too long. This limits my ability to have multiple upstreams (the extra peers are IX’s and bi-lateral peering)
Run about average 15 routing filters (some are shared chains) per peer.
Really its just about time to import routes and time to filter through route table. Some filters are a bit quicker but, for instance, if I need to know what route 8.8.8.8 is taking, even on 15k routes takes too long to be worthwhile for troubleshooting. (/ip route pr where 8.8.8.8 in dst-address)
Hello, we tried to install CCR1036-8G-2S+ with 6.27 and connect it to our peers, the main trouble is performance of the BGP process even we had just two sessions with our route reflectors sending full internet BGP table (no filters attached) and one external peer sending full tables with easy filtering.
It takes about ~5-7mins to remove routes from mikrotik routing table if the external peer is disconnected.
how many peers;
3 with full internet tables, 7 just sending default route and receiving about 20 prefixes
about 500k
no
CCR1036-8G-2S+, peers connected over 10Gb ports
just for BGP, there is no firewall
about 10-20 per min
400 Mbps, tested more than 1500Mb/s in one stream with very low CPU usage (about 20-30% on one cpu)
no, if the Cisco RR is pushing the full table to CCR1036-8G-2S+, CCR1036-8G-2S+ is not able to send keep alives and prefixes back to Cisco RR, cisco output buffer is full for about 5mins
make route processing parallel please and it may be a good box for ISP usage
We have several BGP speaking routers on our network:
how many peers;
8 - 70
100 to 550.000
BGP & OSPF
CCR 1036 - CCR 1016
Of course
~25k/hour
200 - 500 Mbit/s
not frequent
Routes are received very quickly in latest releases (~ 1 min to load the full bgp table). But once loaded the table, routes become active much later (up to 15 minutes!). Also the updates received take a lot of time to become working (several minutes). I would like to see a more rapid network topology change.
The other very important issue is recursive next-hop lookup in IPv6 which is actually causing a lot of problems in deploying v6 on the network.
The origin-as keyword specifies that export statistics include the originating autonomous system for the source and destination.
The peer-as keyword specifies that export statistics include the peer autonomous system for the source and destination.
If traffic flow is being improved, I would also request that fast path support isn’t negated with its use.
I already checked with support on the ability to use v7 as a pure route reflector and was happy to hear that functionality will be included.
Using multiple peers, especially on an internet exchange, both of these features become very important in managing many peers. The CCR series is becoming more and more powerful and RouterOS is improving software performance, but without these two important features, many will be stuck with the competition.
Thanks for checking in mrz. I’m looking forward to v7
+1 for both of these. I have requested the Netflow v9 origin-as and peer-as features directly to Mikrotik support, they notified me that they will try and bring these to RouterOS v7 as it requires the new-routing engine.
This is already possible:
Create ip/vrf
Create bgp/instance
Assign bgp/instance to ip/vrf
Create bgp/vrf
Connect to peers and see their routes only in the VRF table you created above
Success!
We have been running this in production for many years now. Or maybe you mean something else ?
Most of em stay up as router uptime
300Mbit/s
It’s in a IX so there are some flappings, but rare.
When i make some change on filters, router sometimes becomes not responsive, but the traffic keeps forwarded. Looks like the CPU is topped and winbox suffers it.
Route changes converge very slowly if one peer with Full route table is involved in some changes
CPU never goes up more than 5% but one core is always 100% (bgp process?)
If i open a winbox window of /ip route, after a while winbox freezes, and when i close and reopen the connection, winbox tries to load the 1M routes again.
/bgp advertisement in winbox is not usable at all
