does someone know what can make the router stop working?
is there any way to know ?
RouterBOOT booter 3.18
RouterBoard 411U
CPU frequency: 300 MHz
Memory size: 32 MiB
NAND size: 128 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
^Copendir: No such file or directory
ERROR: no system package found!
Kernel panic - not syncing: Attempted to kill init!
There are many different reasons and you have to diagnose it on a case-by-case basis. In your particular case, it seems safe to say that it is a result of filesystem corruption, or a bad NAND. You will need to re-Netinstall RouterOS, and if that doesn’t work, then you have a bad board (though I’m about 95% confident Netinstall will fix it).
4 Years later… Still the best little thread I’ve come across. RB2011 ate crap after a POE power outage/spike recently. Seems they don’t like HV/POE issues.
